Author Topic: Max rpm on a 1.6td? [New mods coming]  (Read 6565 times)
September 05, 2006, 08:38:02 am
klang
  • 29
« on: September 05, 2006, 08:38:02 am »
Hey.
I have just adjusted my 1.6td pump, but, now that i get loads of turbopressure, I'd like to be on higher RPMs.
Is it the pump who stops the RPM or is it the camshaft?
If it is the pump, how do you adjust/modify this?
Regards.
Klang, sweden
Reply #1September 05, 2006, 09:33:50 am
Benjamin
  • 485
« Reply #1 on: September 05, 2006, 09:33:50 am »
the pump dont give the diesel, on something lke 2-3000rpm the governer will start kick in, you need to read the FAQ, "governermod", also read more power for a 1.6td/1.9td.
the camshaft also limits the rpm, but thats in higher rpm's, 935racer sell's race camshafts
Greetz, Benjamin
Must make +250hp
Reply #2September 05, 2006, 07:22:05 pm
SMOKEYDUB
  • 630
« Reply #2 on: September 05, 2006, 07:22:05 pm »
i have revved into my fuel gauge were the rpm limit pin is inside of the tach with a stock cam shaft and the governor mod on my old 1.6td running 26 psi and lots of fuel.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3September 05, 2006, 07:24:45 pm
« Reply #3 on: September 05, 2006, 07:24:45 pm »
Quote from: SMOKEYDUB
into your fuel gauge??? thats like... 6200-400 rpm???????????????????????????????????????????????????????????????
Reply #4September 06, 2006, 10:59:26 am
klang
  • 29
« Reply #4 on: September 06, 2006, 10:59:26 am »
Thanks for all of your answers.
I looked at the governors mod, I am going to go ahead and fix this.
Allthough, It feels like I'm loosing Turbopressure, I checked this with at gauge, and at 0,85 BAR (12 PSI), the pressure suddenly drops, and with loads of smoke  :roll:
Anyways, could this problem be my BOV? Or is my adjusting of the pump that is causing this?
I know the BOV mod. Is this what I need to do?
The pump cant deliver enough fuel?
I just searched on the subject, and the BOV is suppose to blow off at 12PSI, so therefore I think my problem lies here, I'll check this out tomorrow..
Reply #5September 06, 2006, 01:14:16 pm
« Reply #5 on: September 06, 2006, 01:14:16 pm »
its most likely the BOV.  no wait... its definitely the BOV :)
the BOV will dump all your precious boost air, and closes at around a couple of PSI boost.  Yea get that thing blocked off asap :)
some guys on here put a piece of wood on the BOV and use clamps to secure its position (forces the BOV to stay closed, since it opens outward)
Reply #6September 06, 2006, 03:50:24 pm
SMOKEYDUB
  • 630
« Reply #6 on: September 06, 2006, 03:50:24 pm »
ya about 6200 ish..... :D
(courtesy of GILES)
Reply #7September 06, 2006, 04:26:13 pm
zagarus
  • 619
« Reply #7 on: September 06, 2006, 04:26:13 pm »
nah, just get a 6mm X 20mm allen bolt, replace the spring thats in the BOV. Best 45 cents i ever spent  :D
Reply #8September 06, 2006, 07:34:32 pm
« Reply #8 on: September 06, 2006, 07:34:32 pm »
i revved to 6000 some rpm before, but it was on accident, i was in 4th winding it out and went to go to fifth and i was absent minded at the time and i went to 3rd, lol i quickly depressed the clutch though, no harm done
Reply #9September 06, 2006, 07:36:30 pm
SMOKEYDUB
  • 630
« Reply #9 on: September 06, 2006, 07:36:30 pm »
did that what i was shifting with the accelerator on the flor and let the clutch all the way out OUCH!!!! all was fine but i have nevver heard something sound like death before lol.
(courtesy of GILES)
Reply #10September 07, 2006, 08:20:08 pm
hillfolk'r
  • 1532
« Reply #10 on: September 07, 2006, 08:20:08 pm »
i never had luck with the governor mod,i didnt like the way it drove
i didnt feel more power up top,and if you pushed the clutch in for a shift, the revs would "hang" at whever you revved it to,and wouldnt come down unless you were in gear and used the brakes to slow it down
theres more power in the max fuel screw and the adjustments made elsewhere to the pump
Throttle cables ftw
Reply #11September 08, 2006, 05:54:13 am
klang
  • 29
« Reply #11 on: September 08, 2006, 05:54:13 am »
Quote from: hillfolk'r
Please tell me more :)
I fixed the BOV, of well, i broke it, I got me all pissed of so it fell in to small pieces..heh..
Its now held together in a reall hillbilly-way, lots of glue and different bolts and nuts and washers..
but hey it works ;)
The difference after the BOV mod, is like night and day.
Its REALLY fun to drive a golf again, and i love the sound of the wastgate =)
I built a 2" system all the way with no mufflers...
Sweet sound.
I beat LOADS of gassers know, and if they get to close, I show some smoke ;)
I can actually hear the turbo spinning on idle rpm, I knewer dreamed of this effect, just adjusting the turbo / pump/ bigger exhaust..
Next step is to mount and intercooler, or what do you folks think?
What other changes can I do?
Regards, One really happy Klang :D
Reply #12September 10, 2006, 04:19:47 am
« Reply #12 on: September 10, 2006, 04:19:47 am »
definitely do the intercooler.  it will make your car smoke less, so you can increase the fuel  :twisted:
Reply #13September 10, 2006, 04:58:19 am
klang
  • 29
« Reply #13 on: September 10, 2006, 04:58:19 am »
Quote from: jtanguay
heh,yeah, but I cant increase fueling no more, because my idle rpm goes high, and theres no more adjusting I can do on the idle, the bolt is gone =P
So if I increase fueling now, I get higher idle RPM... Is there any other way to adjust it?
Regards Klang
Reply #14September 10, 2006, 06:51:53 am
« Reply #14 on: September 10, 2006, 06:51:53 am »
Quote from: klang
Regards Klang
i think you can move the position of the lever on the throttle shaft,  but do a search and make sure ur 100% on it, cause you can eff ish up doing that
