Author Topic: where to get boost pins????  (Read 13983 times)
September 02, 2006, 10:06:29 pm
1.9blues
« on: September 02, 2006, 10:06:29 pm »
i did all the adjustments recommended... except the boost pin thing. why? because i don't have one. i have a 1.9 TD. 1st gear lots of smoke, after that... nothing. i loose power after 3,800 RPM. i think i don't have enough fuel, i can hear the turbo. i don't know how else to increase fuel at high RPM.
my question here is... who sells the aneroid pin ???
thanks...
Reply #1September 02, 2006, 11:50:57 pm
hillfolk'r
  • 1532
« Reply #1 on: September 02, 2006, 11:50:57 pm »
you can make your own,or i thought one was avalable from germany or somethin
i saw also that bully dog makes one too,but i think its a bigger pin,so it wont work,ive got a spare 4b pump,and its' pin  doesnt fit my vw pump
im thinkin someone  on here  makes one
i made mine from a spare one,i can set it on max fuel,or turn it around for max economy
max power setting
max wuss setting
i carry a little tool pack in my car and can turn up my pump in minutes with it
actually i ride around with it turned up most of the time :roll:
Throttle cables ftw
Reply #2September 03, 2006, 08:13:02 am
1.9blues
« Reply #2 on: September 03, 2006, 08:13:02 am »
Nice ....... i actually seen your setup awhile back. I have search the site for the pins. i know lots of people have it, but they never mentioned where to get one. i also know that some people buy the whole pump and swap parts... i checked on ebay and there are lots of different veriation of the same pump, so i was not sure which one. i have never seen the inside of the pump and don't know enough about the pump to make the pin. i am searching for parts now... if i can't find one...then i will consider making one. The funny thing is... junkyard has a lot of VW, but never seen a diesel there.
thanks again for the help... anything is apreciated
Reply #3September 03, 2006, 09:10:42 am
« Reply #3 on: September 03, 2006, 09:10:42 am »
1.9's have boost pins unless urs is an ecodiesel, it's just that there pins suck, if i had a 1.9 and ic ouldn't find a 1.6 pin i would just do what blake did to his 1.6 pin...
Reply #4September 03, 2006, 04:57:42 pm
scopefrfd
  • 289
« Reply #4 on: September 03, 2006, 04:57:42 pm »
my friend picked up an aftermarket HP boost pin in germany for me.  It has a narrow and steep profile.  I put it in a M-tdi and it made a big difference over the old fiat td pin which BTW is steeper than a vw.  Best $75 spent...power wise.
Reply #5September 04, 2006, 08:40:05 am
« Reply #5 on: September 04, 2006, 08:40:05 am »
75 bucks, ouch
Reply #6September 04, 2006, 08:41:14 pm
scopefrfd
  • 289
« Reply #6 on: September 04, 2006, 08:41:14 pm »
when you take into account how much work it is to make a pin properly...$75  is a good deal.  My turbo spools up much faster now..makes 23psi very quickly.
Reply #7September 04, 2006, 09:22:42 pm
hillfolk'r
  • 1532
« Reply #7 on: September 04, 2006, 09:22:42 pm »
i "borrowed" the profile of a "bully dog" pin at work,others may not be as lucky as me :roll:
besides when i wanna "turn it down",i just rotate it to a stock spot
i usually leave the plastic washer off of the pin,and i have my starwheel fully bottomed,its probably about 2 turns to do that
Throttle cables ftw
Reply #8September 05, 2006, 10:56:37 am
BellCityDubber
  • 251
« Reply #8 on: September 05, 2006, 10:56:37 am »
Quote from: "hillfolk'r"
I tried to do the pin rotation thing but it looks like the profile is the same all around the pin, am I supposed to cut my own profile on the pin?
Reply #9September 06, 2006, 10:08:25 pm
1.9blues
« Reply #9 on: September 06, 2006, 10:08:25 pm »
can anyone give me the measurement for the pin's profile? when it starts to when it ends... can't be cutting profile if i don't know where to cut.
also... for the 1.9 td what will keep the pin from turning back. the 1.6L have a nut and screw to hold the pin in place, 1.9L don't
i don't know if the dealer will sell the top part of the 1.6L pump??
thanks for the help guys
Reply #10September 07, 2006, 08:32:46 am
1.9blues
« Reply #10 on: September 07, 2006, 08:32:46 am »
sorry....i don't think that i was clear in my request. i just need the lenght from the top of the cone to the bottom... i want to know how long it is. i perfer to know the length of the original from the 1.6.
Reply #11September 07, 2006, 08:14:33 pm
hillfolk'r
  • 1532
« Reply #11 on: September 07, 2006, 08:14:33 pm »
lookat your orig pin,you will see a little scratch on its length where it was normally riding,thats its travel area,and you get more  travel if you remove the plastic washer
maybe this helps??
Throttle cables ftw
Reply #12September 07, 2006, 10:46:37 pm
1.9blues
« Reply #12 on: September 07, 2006, 10:46:37 pm »
thank you all.... will do this mod in the week end
Reply #13September 08, 2006, 03:38:51 pm
« Reply #13 on: September 08, 2006, 03:38:51 pm »
in the weekend, do it now it takes 5 minutes
Reply #14September 08, 2006, 04:13:18 pm
BellCityDubber
  • 251
« Reply #14 on: September 08, 2006, 04:13:18 pm »
I'm still curious...
I have to make the curve on the pin, dont I?
