Author Topic: Volvo D24  (Read 47989 times)
Reply #30March 14, 2007, 05:09:11 am
Turbinepowered
  • 1206
Volvo D24
« Reply #30 on: March 14, 2007, 05:09:11 am »
Quote from: "745 turbogreasel"
D24 is staright up, D24T has ganngsta lean to the passenger side.
You sure? I was looking at a 240 diesel with the D24 in it about a month ago, and it had the same side-tilt as the Audi engine did... at least, I believe it did. Would make sense, seeing as how the 2.4 and the 2.0 (And the 1.6, for that matter) are all the same height. Maybe how the engine was laid out made it look flopped over?
I swear I was looking -down- at the glow-plugs when I was futzing around with them, rather than across at them...
Reply #31March 14, 2007, 03:00:57 pm
Volvo D24
« Reply #31 on: March 14, 2007, 03:00:57 pm »
the bellhousings are clocked diffferent, maybe the d24 is more leaned  for the long runner intake to clear the hood? but if you use the wrong bellhousing your shifter ends up way out of line.
Reply #32March 14, 2007, 04:34:40 pm
Turbinepowered
  • 1206
Volvo D24
« Reply #32 on: March 14, 2007, 04:34:40 pm »
So it's a bell-housing pattern shift, and not a pattern shift on the engine block? That would make sense, I suppose.
Reply #33March 14, 2007, 10:28:54 pm
Volvo D24
« Reply #33 on: March 14, 2007, 10:28:54 pm »
that and the engine mount arms, I think mybe the turbo fouls d24 arms
Reply #34March 17, 2007, 06:17:15 am
IRoll
  • 25
Volvo D24
« Reply #34 on: March 17, 2007, 06:17:15 am »
I'm no expert, but I do believe the D24(featured in the 200 series Volvo's) and the D24T(700 series) both lean approximately the same amount.
     As for motor mounts, I've got a D24T is a 200 series Volvo. I am pretty sure they use different mounts for the 200s and 700s, So I must have the 200 kind. I've just got it to run (rebuild the engine) so I haven't gotten it out and driven it yet, but if the D24T can foul these mounts, I will make it happen. Just give me a few months.:wink:
     Just go for the stock Volvo tranny (M46: 4spd with electric overdrive Or the M47: 5spd, a little more rare) I think that would be the simplest way to go.
         -E
How fast?
As fast as it takes.
Reply #35March 18, 2007, 10:32:27 am
deezul ryan
  • 24
    • http://www.dieseldude.com
Volvo D24
« Reply #35 on: March 18, 2007, 10:32:27 am »
Quote from: itzdshtz
Deezul ryan, did you use a Volvo tranny in your Jeep or did you use an adapter?
i used jeep tranny (ax5) that is actually a toyota trans,jeep slave cyl,jeep clutch and pilot bearing .volvo/vw flywheel bellhousing pressure plate  throwout bearing and the fork that operates the throwout bearing.  i made an adapter to go from the volvo bellhousing to the jeep/toyota trans
94 jeep YJ 2.4 TD (vw diesel powered)
81 vw pickup 2.0 16v dual carbs NOS soon to be TDI-M powered
80 vw pickup 1.5 TD
53 Studebaker M35 7.8 TD (23,030 GVWR)
Reply #36March 20, 2007, 10:41:11 pm
itzdshtz
  • 94
Volvo D24
« Reply #36 on: March 20, 2007, 10:41:11 pm »
Thanks Deezul ryan, I would like to do such a conversion in the future.
I will have to gather some more parts.
                                      Herman
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #37June 20, 2007, 04:37:40 pm
scopefrfd
  • 289
Volvo D24
« Reply #37 on: June 20, 2007, 04:37:40 pm »
I have a 240 and 740 with the D24 and D24T engines and the D24 engines are at different angles.  I think the engine in the 740 is more upright.   Does anyone have any really good pics of the 940 with the Tic intercooler setup?  I would really like to see how the intercooler is mounted.
Reply #38June 20, 2007, 05:42:37 pm
IRoll
  • 25
Volvo D24
« Reply #38 on: June 20, 2007, 05:42:37 pm »
Hey Scopefrfd,
Hows the D24T runnin'?
This is the best I've got:
Hope this helps, let us know how you run it. I would like to get my IC in here sometime.
Good luck
-E
How fast?
Reply #39June 20, 2007, 06:05:35 pm
scopefrfd
  • 289
Volvo D24
« Reply #39 on: June 20, 2007, 06:05:35 pm »
My buddy in germany picked up the Tic intercooler setup for me .  So far I've received all the hoses and hard tubing.  Looking closely at the D24t I was having a hard time visuallizing how it would fit.  The was no way you good use the gas turbo radiator spacers that put the rad closer to the engine..not enough room between the rad and rad fan.  Even with my 940 elec setup there's only an inch or two of space.
I was seriously considering going to a water to air IC..I even test fitted a setup using the N/A D24 intake manifold.  I'm still undecided..I'm waiting for the factory intercooler to arrive..I didn't get the Tic intake manifold..so I have make something custom.  I picked up a N/A intake from a LT truck... it looks like the d24 N/A intake except it's slightly smaller ...lower profile.  Hopefully it'll work.
The car in general is running great...I'm not crazy about it being an automatic, even though the tranny matches the engine really well...I just love sticks.
Reply #40June 21, 2007, 08:38:34 am
Volvo D24
« Reply #40 on: June 21, 2007, 08:38:34 am »
Quote from: scopefrfd
I think all of the 200's had the engines tilted a little, even the gassers.  Most of the 700's had them more upright.  (gas or diesel)  At least that's what I can remember from dealership days.... although I was more a VW fan and didn't pay much attention to the old Volvos.  :P
Reply #41July 01, 2007, 06:15:33 pm
scopefrfd
  • 289
Volvo D24
« Reply #41 on: July 01, 2007, 06:15:33 pm »
Hi IROLL,
the volvo 740td is running great....I just converted the a/c to 134 and recharged.  I removed the original front electric a/c fan that sits in front of the a/c condenser..I need the space for the water to air intercooler radiator.  Since I'm running the electric 2 spd fan from a 940.  A problem is volvo's relay uses grounds for switching the fans on.  No problem with the main high speed fan switch..I use a regular vw coolant switch 190F approx.  My problem was switching on the low speed fan when I use the a/c.  It seems I can use the ground switch of the high pressure side...pressure rises with increased temps in the a/c, so when the refrigerant starts to get hot and I start to lose a little efficiency the switch grounds and the low speed fan comes on.  It actually works much better than I thought and it only stays on when it's needed rather than most cars which run continous.
Someone posted some really nice pics of the d24tic engine....thanks!   What I noticed is the tic rad looks to be much narrower than the a/c d24t's we have here in North America.   Looking really closely at the d24t rad I cannot see how the intercooler piping can get by.  Here in the northeast I think  the factory rad we have in the volvo is probably a little overkill.  My electric high speed setting really doesn't seem to run that much...with the a/c on..the low speed fan is enough to keep the coolant temps in check.  If I'm not running the a/c and I come off the highway into city traffic it usually never runs for more than a minute...very powerful fan.
I was going to go h20 to air but I had to use a d24 intake and have the piping enter the intake from the firewall side of the d24 intake.  I mocked it all up and it all fit...but the D24 intake is much taller than a d24t and I didn't like how close it came to the hood.
My latest idea to get this thing intercooled is to go h20 to air IC again...but this time my buddy in germany sent me a d24 intake but it's a smaller intake..sort of in between the d24 and d24t.  I mocked it up and it looks like it will work if I remove the factory airbox and use a K&N air filter.  I'm going to try and fit it this week sometime...need to match port the intake to the ported head.
I also added the factory 740 turbo boost gauge in the instrument cluster...I calibrated it with my vdo boost gauge.  I had 3 boost gauges and 1 maxed out at 18psi, one at 20 psi, and the last at 22psi... the 22psi gauge is the one I installed along with the factory voltmeter. finally all the pods are used up.  I have a egt gauge mounted just right of the ignition...to me out of all the gauges that's the one I really watch.  Non-intercooled and at 20+psi going up a hill I can get a little over 1200F.
Reply #42October 16, 2007, 07:29:57 pm
ranger station
  • 11
    • http://www.freewebs.com/rangenstation
24D
« Reply #42 on: October 16, 2007, 07:29:57 pm »
Hey!!
  Just found this site and was glad to hear others talking about the 24D.
  I have a 88 Ranger short box that I installed a 24D in. It has the 4 speed volvo trans with electric overdrive. The truck was totaly dismanteled and frame sandblasted,painted. All new body panels where needed, new brakes,lines, power steering box, power brake booster, etc,etc and I made the front end flip ahead.
  The engine was totaly rebilt including boring and the fuel system. I added a turbo and intercooler ( limited the boost to 16Lb).
  I am geared a little slow but still getting close to 40 mi/gal imp.
  I do not have the interior complete yet, but am work n on it.
  I do not drive the truck in the winter time so have toyed with the idea of installing a 1.9turbo in a ranger.
  If anyone has any new info on adapting to a ranger trans, I would love to hear it.
  Happy Dieseling !!
Reply #43November 13, 2007, 08:52:27 am
Quantum TD
  • 1195
Volvo D24
« Reply #43 on: November 13, 2007, 08:52:27 am »
FYI: I'm not sure how stout the D24T motor is, but my dad had the 6cyl NA D24 (Audi/VW diesel motor) in a 1984 Volvo wagon. It was a complete heap of ***. He rebuilt the motor twice in a 1 year span (new pistons and all). Each time he rebuilt it, it got serious blowby wihtin months.
If you're considering the swap nonetheless, then try to find GAMBIT (user name) from Knoxville TN on tndubs.com. He's doing the 6 cyl Turbo diesel (from a 740 TD)swap into a Quantum Syncro wagon. He's measured it all up and it will work, but as noted by others in this thread, you'll have to do some cutting up front. I'm not sure how far along he is, or if he's still doing it, but that was his plan 2 months ago. He might be able to lend some advice if you're still into this.
Reply #44November 13, 2007, 10:39:01 am
Turbinepowered
  • 1206
Volvo D24
« Reply #44 on: November 13, 2007, 10:39:01 am »
Nah, going the five cylinder route, 116hp TDI imported through an importer. But thanks for the tip!
