Author Topic: Bosch distributor injection pump identification  (Read 17620 times)
August 22, 2006, 10:45:59 pm
935racer
« on: August 22, 2006, 10:45:59 pm »
Example:
V E 4 / 9 F 2400 L 12
V: Distributor injection pump
E: Axial piston high pressure pump or R: radial piston high pressure pump
2-6: Number of high pressure outlets
8-12: Pump plunger diameter in mm.
F: Mechanical governor or E: Electric actuator mechanism or M: high pressure solenoid valve.
2400: Upper pump nominal speed (half of engine rpm)
L: Counter clockwise or R: Clockwise (view toward pump drive)
12: Type code.
Reply #1January 16, 2007, 12:28:16 pm
wolfsburgnut
  • 126
« Reply #1 on: January 16, 2007, 12:28:16 pm »
This really helps to get the number Dave is talking about.
 http://ecat-online.bosch.de/toc/frame1.html
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #2March 16, 2007, 11:41:30 am
subsonic
  • 1836
So which ones are these?
« Reply #2 on: March 16, 2007, 11:41:30 am »
Alright,  I got some spare time between working, changing diapers and trying to finish off a basement remodel, to start working on my TD build.  I pulled one of the IP's off, and cleaned up the id plate on the other to pull the numbers off.  I cant seem to use the product decypher/ID that you posted Dave in order to figure out what I have.
Once I get the new digital camera software loaded on the computer I will add some pics.
Here's what I have:
I am not sure what year these came out of,  one may be a 92.
Pump #1
NR  0  460  494  182
R  223  BT  4007
VW/Audi  068  130  130  081F
015  644              39515
Pump #2
NR  0  460  494  162
VE  R  188
VW/Audi  068  130  110H
011  541              189  68
Gonna do some more searching, and more head scratching. :?   I am trying to determine which is the best pump for the Giles mod.
Thanks, Jim
