Author Topic: IP pump Id  (Read 4576 times)
October 08, 2024, 10:05:03 am
homerj1
  • 433
IP pump Id
« on: October 08, 2024, 10:05:03 am »
Can anyone id if this is a 1.6td pump or a AAZ pump?
Thanks
Reply #1October 08, 2024, 12:13:32 pm
Re: IP pump Id
« Reply #1 on: October 08, 2024, 12:13:32 pm »
this looks like an aaz pump because of the shape of the "snout" or nose. a part number would be the best way to tell
Reply #2October 08, 2024, 03:10:54 pm
homerj1
  • 433
Re: IP pump Id
« Reply #2 on: October 08, 2024, 03:10:54 pm »
There are no id #s on the pump except for
 " The numbers i can find are...
468 stamped into the housing beside the fuel inlet.
& CHJ 0631 printed on the delivery head"
The above is from the seller of the IP. Also the pump was rebuilt, not used & stored for the past 10 years, so I figure the insides might be a bit gummy?
« Last Edit: October 08, 2024, 03:12:31 pm by homerj1 »
Reply #3October 09, 2024, 05:31:43 am
Re: IP pump Id
« Reply #3 on: October 09, 2024, 05:31:43 am »
Its possible that it's gummy, I bought one that had sat for about 4 years and the governor weights were stuck in it. it was an easy fix. I still have this pump if you'd like to buy it. I ran it until 2017 when the engine failed, then it sat in the car with fuel in it until about 1-2 years ago, since then it's been stored in my garage, it has a vanagon-style throttle lever on it
« Last Edit: October 14, 2024, 06:45:03 pm by ORCoaster »
Reply #4October 14, 2024, 05:49:50 am
homerj1
  • 433
Re: IP pump Id
« Reply #4 on: October 14, 2024, 05:49:50 am »
PMed you RabbitJockey
