Author Topic: More surging issues  (Read 21490 times)
November 22, 2022, 05:41:23 am
srgtlord
  • 797
More surging issues
« on: November 22, 2022, 05:41:23 am »
So after another extended trip on the highway the old 85 golf is experiencing surging issues at part throttle. At first I thought the pump bolts loosened up but I checked all of them and they were fine. I have 2 educated guesses for this one on what the issue is
1. Timing belt
The belt probably has over 65,000 miles on it by now and after popping the cover off I see oil on the belt
2. The injection pump
I noticed the pump was leaking again after 10 years
Ill do the timing belt job and report back
Reply #1November 22, 2022, 09:39:12 pm
  • 2922
Re: More surging issues
« Reply #1 on: November 22, 2022, 09:39:12 pm »
Which bolts did you check?
 The ones holding the mounting bracket to the block?
Reply #2November 23, 2022, 10:53:45 am
srgtlord
  • 797
« Reply #2 on: November 23, 2022, 10:53:45 am »
I checked the bolts holding the pump to the mounting bracket. Hmm I might have to check the ones holding the bracket to the block
Reply #3November 23, 2022, 07:30:45 pm
  • 2922
« Reply #3 on: November 23, 2022, 07:30:45 pm »
yep,
and they are hard to get to.
 Those 2 bolts are also used to adjust where the belt rides on the sprocket.
 I always blue locktite them after the belt is riding in the right place.
When they are loose you might also feel a vibration on the accelerator/your foot.
« Last Edit: November 23, 2022, 07:32:51 pm by fatmobile »
Reply #4November 24, 2022, 08:38:16 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #4 on: November 24, 2022, 08:38:16 am »
Seconded. It's happened to me before.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #5November 27, 2022, 01:58:44 pm
RustyCaddy
  • 395
« Reply #5 on: November 27, 2022, 01:58:44 pm »
On the very off chance what i had experienced might apply to your situation, the bolt holding the sprocket to the crankshaft came lose once and backed out a couple of millimeters. The sprocket was traveling slightly but still rode the woodruff key.  The engine would advance and retard, back and forth so sometimes it felt like it was surging.
Reply #6November 28, 2022, 02:55:12 pm
srgtlord
  • 797
« Reply #6 on: November 28, 2022, 02:55:12 pm »
Well I'll be damned.... 3 of the 4 bolts holding the pump bracket to the block are gone and the 4th is barely threaded on.... Holy crappers.......
Reply #7November 28, 2022, 06:55:41 pm
  • 4549
« Reply #7 on: November 28, 2022, 06:55:41 pm »
Caught in the nick of time.  That could have be an exploding momment if that IP came unbolted.
Reply #8November 28, 2022, 08:14:15 pm
  • 2922
« Reply #8 on: November 28, 2022, 08:14:15 pm »
3 out of 4 and the last one was loose.
 That's bad.
 So the pump was bolted on,.. to a bunch of loose brackets, ha.
 Could have been a much worse ending.
 Blue  locktite them back in.
Reply #9November 30, 2022, 06:56:26 am
srgtlord
  • 797
« Reply #9 on: November 30, 2022, 06:56:26 am »
Yeah I'm going to steal the bolts off my spare engine and put them in this weekend. This is looking like a Sunday afternoon project
Reply #10November 30, 2022, 09:18:43 am
  • 4549
« Reply #10 on: November 30, 2022, 09:18:43 am »
Just go to the hardware store and get some new bolts.  Easier than removal from engine B for engine A.  You have one to use as a match.
They do sell those metric bolts here in America you do know that?!!
Reply #11November 30, 2022, 01:13:05 pm
srgtlord
  • 797
« Reply #11 on: November 30, 2022, 01:13:05 pm »
Yeah but the rust prevention/coating is much different on the hardware store bolts I've noticed. Even the "stainless" bolts start rusting in a few years. But overall to save on the headache of pulling apart the spare engine I'll just pick some new bolts up as suggested
Reply #12November 30, 2022, 03:18:42 pm
  • 4549
« Reply #12 on: November 30, 2022, 03:18:42 pm »
Don't worry about the rust, they will have a good coating of oil/diesel on them most of the time.
Reply #13November 30, 2022, 04:01:30 pm
  • 2922
« Reply #13 on: November 30, 2022, 04:01:30 pm »
You have to remove the oil on the bolts and holes to get the locktite to stick.
Reply #14December 13, 2022, 02:13:21 pm
srgtlord
  • 797
« Reply #14 on: December 13, 2022, 02:13:21 pm »
Welp got the whole thing back together and running like a champ now
