General Information
Troubleshooting
More surging issues
Topic: More surging issues (Read 22811 times)
November 22, 2022, 05:41:23 am
srgtlord
More surging issues
November 22, 2022, 05:41:23 am »
So after another extended trip on the highway the old 85 golf is experiencing surging issues at part throttle. At first I thought the pump bolts loosened up but I checked all of them and they were fine. I have 2 educated guesses for this one on what the issue is
1. Timing belt
The belt probably has over 65,000 miles on it by now and after popping the cover off I see oil on the belt
2. The injection pump
I noticed the pump was leaking again after 10 years
Ill do the timing belt job and report back
November 22, 2022, 09:39:12 pm
Re: More surging issues
November 22, 2022, 09:39:12 pm »
Which bolts did you check?
The ones holding the mounting bracket to the block?
November 23, 2022, 10:53:45 am
srgtlord
November 23, 2022, 10:53:45 am »
I checked the bolts holding the pump to the mounting bracket. Hmm I might have to check the ones holding the bracket to the block
November 23, 2022, 07:30:45 pm
November 23, 2022, 07:30:45 pm »
yep,
and they are hard to get to.
Those 2 bolts are also used to adjust where the belt rides on the sprocket.
I always blue locktite them after the belt is riding in the right place.
When they are loose you might also feel a vibration on the accelerator/your foot.
Last Edit: November 23, 2022, 07:32:51 pm by fatmobile
November 24, 2022, 08:38:16 am
Rabbit79
Burns, Oregon,USA
November 24, 2022, 08:38:16 am »
Quote from: fatmobile on November 22, 2022, 09:39:12 pm
Seconded. It's happened to me before.
Current: 1979 Rabbit 4dr
1984 F-250
1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
70 Bug
November 27, 2022, 01:58:44 pm
RustyCaddy
November 27, 2022, 01:58:44 pm »
On the very off chance what i had experienced might apply to your situation, the bolt holding the sprocket to the crankshaft came lose once and backed out a couple of millimeters. The sprocket was traveling slightly but still rode the woodruff key. The engine would advance and retard, back and forth so sometimes it felt like it was surging.
November 28, 2022, 02:55:12 pm
srgtlord
November 28, 2022, 02:55:12 pm »
Well I'll be damned.... 3 of the 4 bolts holding the pump bracket to the block are gone and the 4th is barely threaded on.... Holy crappers.......
November 28, 2022, 06:55:41 pm
Moderator
4552
November 28, 2022, 06:55:41 pm »
Caught in the nick of time. That could have be an exploding momment if that IP came unbolted.
November 28, 2022, 08:14:15 pm
November 28, 2022, 08:14:15 pm »
3 out of 4 and the last one was loose.
That's bad.
So the pump was bolted on,.. to a bunch of loose brackets, ha.
Could have been a much worse ending.
Blue locktite them back in.
November 30, 2022, 06:56:26 am
srgtlord
November 30, 2022, 06:56:26 am »
Yeah I'm going to steal the bolts off my spare engine and put them in this weekend. This is looking like a Sunday afternoon project
November 30, 2022, 09:18:43 am
Moderator
4552
November 30, 2022, 09:18:43 am »
Just go to the hardware store and get some new bolts. Easier than removal from engine B for engine A. You have one to use as a match.
They do sell those metric bolts here in America you do know that?!!
Reply #11
November 30, 2022, 01:13:05 pm
srgtlord
Reply #11 on:
November 30, 2022, 01:13:05 pm »
Yeah but the rust prevention/coating is much different on the hardware store bolts I've noticed. Even the "stainless" bolts start rusting in a few years. But overall to save on the headache of pulling apart the spare engine I'll just pick some new bolts up as suggested
Reply #12
November 30, 2022, 03:18:42 pm
Moderator
4552
Reply #12 on:
November 30, 2022, 03:18:42 pm »
Don't worry about the rust, they will have a good coating of oil/diesel on them most of the time.
Reply #13
November 30, 2022, 04:01:30 pm
Reply #13 on:
November 30, 2022, 04:01:30 pm »
You have to remove the oil on the bolts and holes to get the locktite to stick.
Reply #14
December 13, 2022, 02:13:21 pm
srgtlord
Reply #14 on:
December 13, 2022, 02:13:21 pm »
Welp got the whole thing back together and running like a champ now
General Information
Troubleshooting
More surging issues
