VWDiesel Blog
Facebook Group
VWD on Twitter
Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
Loose oil pan bolts!
Topic: Loose oil pan bolts! (Read 3467 times)
September 07, 2022, 10:11:38 pm
oblique
September 07, 2022, 10:11:38 pm »
After pulling the stamped metal cover...do I need to check the flywheel for broken teeth?
September 07, 2022, 11:11:46 pm
Moderator
Re: Loose oil pan bolts!
September 07, 2022, 11:11:46 pm »
I would if it were my engine.
September 08, 2022, 12:19:40 am
September 08, 2022, 12:19:40 am »
I'm not sure how those bolts would end up on the pressure plate side of the tin cover.
Tornado red, '91 Golf 4 door,
September 08, 2022, 09:53:10 am
oblique
September 08, 2022, 09:53:10 am »
The bolts are behind the cover, you have to remove it to access them to drop the pan, at least on my car
September 09, 2022, 01:19:12 am
September 09, 2022, 01:19:12 am »
Yours has the small removeable lower cover right?
I haven't seen one of those in awhile,..
but I'm still thinking the oil pan is outside of it.
September 09, 2022, 11:22:53 pm
oblique
September 09, 2022, 11:22:53 pm »
yea its a double thick stamped metal plate with 2-11mm bolts..says 020 on it. ill take a pic to confirm...when i first looked at it i thought i would have to remove the trans to drop the pan.
i did not know these were not all the same...
September 16, 2022, 06:49:19 am
oblique
September 16, 2022, 06:49:19 am »
Hopefully you can see the rim of the pan going past the plate.
Last Edit: September 16, 2022, 06:51:39 am by oblique
September 17, 2022, 07:32:35 pm
Moderator
September 17, 2022, 07:32:35 pm »
I have never seen that alignment before. Almost like the engine is into the bell housing a wee bit far.
September 17, 2022, 07:57:37 pm
oblique
September 17, 2022, 07:57:37 pm »
To access the 2 hidden bolts the stamped cover comes off and they are reached at an angle due to the bellhousing.
I have to say its a little strange that this isn't standard. Is the bellhousing code stamped anywhere? This must be an extra protrusion of the bellhousing past the pan, otherwise there would be dimensional issues relative to the chassis.
September 18, 2022, 07:42:42 pm
Moderator
September 18, 2022, 07:42:42 pm »
Not that I know of. The only stamp on the bell housing I am familiar with is the date of build and type of transmission that is just on that flat area where you are working.
September 19, 2022, 12:37:07 am
September 19, 2022, 12:37:07 am »
I think the stamp says AGS.
Those separate lower covers stick out farther toward the engine than I remember.
Reply #11
September 19, 2022, 09:07:16 pm
Moderator
Reply #11 on:
September 19, 2022, 09:07:16 pm »
ASF ?6059
Reply #12
September 23, 2022, 03:15:09 am
oblique
Reply #12 on:
September 23, 2022, 03:15:09 am »
On a side note I changed the trans oil yesterday and 1. It was short...1.5L at most and 2. It was light brownish and metallic. No discernable metal fragments but it poured like metallic paint, had that sheen on it. If its super old fluid could be just regular wear i suppose but also 5th gear sits higher on the 020, correct?
Reply #13
September 23, 2022, 10:51:47 pm
Moderator
Reply #13 on:
September 23, 2022, 10:51:47 pm »
Correct, so if you were a bit low it would leave 5th kinda dry. That is why I pull the speedo cable and fill it from there. Much easier to do that than tip the trans to get what you really need in there.
