VWDiesel Blog
Facebook Group
VWD on Twitter
Delivery valves
Topic: Delivery valves (Read 1075 times)
July 18, 2022, 03:21:42 pm
Tomoturbo55
Delivery valves
July 18, 2022, 03:21:42 pm »
Should fuel leak out of the pump when delivery lines are removed?
Anybody ever encounter bad delivery valves? Should they work one way or Like both ways of fuel flow to pump and injectors?
July 18, 2022, 11:26:09 pm
Moderator
Re: Delivery valves
July 18, 2022, 11:26:09 pm »
I believe they only allow fuel out to the injectors. And yes they can get plugged up and can be cleaned up.
July 19, 2022, 01:58:29 pm
Re: Delivery valves
July 19, 2022, 01:58:29 pm »
I think it depends what pump you have.
Later pumps will flow out the delivery valves when the lines are removed.
If you remove the delivery valves you can inspect them.
The circular area should have machine marks that go around it.
If you can't see the lines going around and there are lines going parallel to the valve it is worn.
Tornado red, '91 Golf 4 door,
July 31, 2022, 06:47:21 pm
sgnimj96
Re: Delivery valves
July 31, 2022, 06:47:21 pm »
Should replace those copper washers (6x10?) when you put them back in. Those dv's see full injection pressure.
I read somewhere to tighten and loosen in 3 increasing steps to the final torque
Last Edit: July 31, 2022, 08:45:40 pm by sgnimj96
81 Scirocco 1.6D (conversion) 86 Gofl 1.6D 2003 Golf Tdi 1985 300TD
Delivery valves
