VWDiesel Blog
Facebook Group
VWD on Twitter
Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
Tricks to Remove Exhaust "C" Spring Clamps????
Topic: Tricks to Remove Exhaust "C" Spring Clamps???? (Read 4884 times)
April 08, 2021, 11:21:40 am
thomas m
April 08, 2021, 11:21:40 am »
Can I get some ideas on how to remove those pesky "C" spring clamps that
hold the down pipe to the exhaust manifold?? References in the forums
would be great. Thanks.
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
April 08, 2021, 05:05:25 pm
srgtlord
Re: Tricks to Remove Exhaust "C" Spring Clamps????
April 08, 2021, 05:05:25 pm »
Go to the autoparts store and buy a cheapo exhaust clamp and flip it upside down. You place it inside the C clamp and use it to expand them
April 10, 2021, 12:48:59 am
April 10, 2021, 12:48:59 am »
Yep that's the standard trick.
But to remove them I grab a screwdriver and stick it through one of the holes and spin the clamp until it pops off.
Goes flying.
Tornado red, '91 Golf 4 door,
April 10, 2021, 11:06:14 pm
Moderator
April 10, 2021, 11:06:14 pm »
Thomas m, you may be confused by what Sarge mentioned in that by turning it upside down he meant that you take it apart first. So instead of having an O clamp, you turn that flat part so it points out and away from the U shape of the other part. Then you put it back on that way but put the nuts on first. They will act as pushers, no not that kind, to move the flat part away from the U.
Now make it all small enough to slide behind the two C's of your clamp. By turning the nuts a bit at a time you force the C open to where you can just lift it off the doughnut part.
Follow all that?
April 15, 2021, 08:21:55 pm
thomas m
April 15, 2021, 08:21:55 pm »
Yes, clear enough.
Convert the CLAMPER into an EXPANDER.
I suppose that you could use a piece of threaded rod bent into a kind of "square U"
and accomplish the same thing.
320,000 miles
April 16, 2021, 12:59:22 am
Moderator
April 16, 2021, 12:59:22 am »
yepper, just need to get some sort of straight piece across the U shape to force the clamp apart.
April 18, 2021, 12:57:55 am
April 18, 2021, 12:57:55 am »
I think you are better off with a curved piece.
Like the exhaust clamp has when you flip it.
May 12, 2022, 02:42:19 pm
zip1916
Newbie
May 12, 2022, 02:42:19 pm »
There really isn't a good trick you can do. Removing them is easy, as you can just pry them off with a screw driver. Getting them back on is the hard part. Especially on the turbo side (assuming you have a turbo diesel). The OEM tool for the job costs about 14$ in my country, in my local tool shop. If would advise you to get it.
May 12, 2022, 11:14:03 pm
Moderator
May 12, 2022, 11:14:03 pm »
zip1916, I object, using a simple muffler clamp as an expander instead of a clamp is the best trick there is. What's a clamp cost these days? 8 bucks?
