S-PAutomotive.com
Author Topic: 02A swap mount questions  (Read 2758 times)
June 14, 2020, 01:47:30 pm
JFKO
  • 13
« on: June 14, 2020, 01:47:30 pm »
Hey guys im in the process of doing a 02A swap in my mk2 mtdi from a 020. the gearbox is the one that came with the ahu engine so a CTN code gearbox. and it came off of a mk3 golf, but i've ran into a couple of problems in the process. im using the 02A aluminium rear transmission mount, but the bolt hole dont line up, the red dot in the picture is roughly where the hole should be. so question. Do i need to use the 020 rear mount? at a quick glance when it took the 020 off it didn't seem like it would fit on the 02A, and most of the posts i've read say that i/you need to use the 020 front mount and the 02A rear mount. but that's not the case for me for some reason. and for some reason the bolts and rubber boot on the 100mm inner cv's that i bought for a mk3 hits the mount mentioned before that's where the blue circle is in the picture. i guess/hope that is just because i can't bolt the mount up?
Can't figure out how to add photos to a post on this site so look at my avatar picture
« Last Edit: June 14, 2020, 01:55:28 pm by JFKO »
1991 Golf Mk2 AHU MTDI and AAZ T3 Single cab
Reply #1July 14, 2020, 10:34:44 pm
harpy
  • 18
Re: 02A swap mount questions
« Reply #1 on: July 14, 2020, 10:34:44 pm »
Not sure if this will help you but someone else just sent me this link today. http://www.20vt.lt/index.php/how-to/32-conversion-to-02j ... that's more so for the shifter and the clutch pedal/cylinder assembly.
Use this site for uploading photos that you can post on this forum: https://imgbb.com/
Reply #2July 16, 2020, 03:33:21 am
JFKO
  • 13
« Reply #2 on: July 16, 2020, 03:33:21 am »
thank you i very much.
