Fixmyvw.com
Author Topic: Current source for AAZ injector lines ??  (Read 2619 times)
May 15, 2020, 03:07:17 am
ms6peters
  • 3
« on: May 15, 2020, 03:07:17 am »
Is there any current source for new AAZ injector lines sets in US, CA or Europe ?
Is Cohline making any AAZ Repro’s ?
The AAZ is in a military M422A1 vehicle.   1st winter stored outside.
Have a rust pit on #2 where the braided return line touches and some on #1.
Hood louvers aggravated the moisture & rust.
Reply #1May 15, 2020, 10:49:06 pm
  • 4393
Re: Current source for AAZ injector lines ??
« Reply #1 on: May 15, 2020, 10:49:06 pm »
Did you look at MK1autohaus?
Reply #2May 17, 2020, 01:08:11 pm
ms6peters
  • 3
« Reply #2 on: May 17, 2020, 01:08:11 pm »
AAZs lines are for a taller set-up than 1.6L - 2 stage injectors, taller block.
Believe I found on Ebay in Europe using part #s for individual lines.
Reply #3May 17, 2020, 01:26:52 pm
  • 3416
« Reply #3 on: May 17, 2020, 01:26:52 pm »
Feel free to post part #'s and links in order to help the next guy.
Reply #4August 06, 2020, 10:58:09 pm
ms6peters
  • 3
« Reply #4 on: August 06, 2020, 10:58:09 pm »
Stocking up on spares since now storing the vehicle outside.
I do have 1 NOS injector line set to replace the lines that deeply pitted last year for an off road rig.
I ordered 2 more sets of what appears as a recent/latest available VW individual part numbers from ebay, a supplier in Latvia.  First #3 attempt was incorrect.  The new #3s just arrived.  These have slightly different bend pattern on #3 and #4, but are the right overall height and spacing....maybe for noise.  This ‘newer’ set won’t accomodate the 4-gang clamp, only two 2-gang clamps.
FYI - part #’s - 1.9 AAZ injector lines
#1 - 028 130 301N
#2 - 028 130 302H
#3 - 028 130 303B
#4 - 028 130 304L
S-PAutomotive.com
