Author Topic: MK3 cluster into MK2 (TD)  (Read 5820 times)
August 10, 2006, 05:35:09 pm
X@V
  • 1002
« on: August 10, 2006, 05:35:09 pm »
I have a MK3 wiring hardness with too much things on it (cruise control, A/C, alarm, etc.)
I need to know how the MK3 cluster could work on a MK2 wiring hardness. It's missing the VSS (3 wires). It's still not working!
What's missing?
Reply #1August 15, 2006, 07:01:41 pm
« Reply #1 on: August 15, 2006, 07:01:41 pm »
it should work
Reply #2August 15, 2006, 07:03:55 pm
X@V
  • 1002
« Reply #2 on: August 15, 2006, 07:03:55 pm »
A wire between E2 to D8 and it works.  :wink:
I installed the MK3 coolong system on the MK2 wiring. It's simple!
Reply #3July 03, 2007, 06:54:03 pm
X@V
  • 1002
« Reply #3 on: July 03, 2007, 06:54:03 pm »
I have trouble
I have only 9V at the E2 to D8 junction.
When I turn the ignition switch on, the display disappear and the cluster doesn't work. The glow plugs indicator works but not the rest.
Do you have an idea?
Reply #4July 03, 2007, 07:48:50 pm
« Reply #4 on: July 03, 2007, 07:48:50 pm »
That's a common problem with the mk3 clusters. Try pulling up on the handbrake and seeing if the cluster works
Reply #5July 08, 2007, 06:33:09 am
somolovitch3
  • 290
« Reply #5 on: July 08, 2007, 06:33:09 am »
If that works, means there is a lack of/poor grounding at the cluster, no?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
