Author Topic: tdi life expectancy?  (Read 43013 times)
August 08, 2006, 12:00:52 pm
iggi
  • 33
« on: August 08, 2006, 12:00:52 pm »
not exactly performance oriented..  but hopefully some owners can share their experience.
How long should a well maintained VW TDI engine last?
I've looked at a couple in the 150,000 mile range.  Will they be good for another 100K?  200K?   :?:
Thanks!
'97 Jetta GL TD
'87 Vanagon Westy
Reply #1August 08, 2006, 12:27:27 pm
vwmike
  • 1158
« Reply #1 on: August 08, 2006, 12:27:27 pm »
I've seen several with over 300k miles on them.
Reply #2August 08, 2006, 02:38:49 pm
iggi
  • 33
« Reply #2 on: August 08, 2006, 02:38:49 pm »
cool, thanks!
'97 Jetta GL TD
'87 Vanagon Westy
Reply #3August 18, 2006, 09:19:48 am
Peter
  • 136
« Reply #3 on: August 18, 2006, 09:19:48 am »
my mechanic friend bought a used 1999  with 270,000mi/400,000k..the car was highway driven, but the piston rings needed changing out( that is why it was sold) ..car was maintained only to the VW specs/9,000-10,000mile oil change.
Reply #4August 18, 2006, 12:41:11 pm
houseofdiesel
  • 210
« Reply #4 on: August 18, 2006, 12:41:11 pm »
I have driven a few in the 300k miles range, one 400k miles, I have taken a couple apart for clogged intakes/cylinder heads and no visual wear in the cylinders at those miles...they seem to last a VERY long time, however some people have bad luck and turbos die, timing belts fail, etc.
Heads always need rebuilding by 300-400k miles (guides, seals etc) but pistons and rings okay still. Way more durable then older VW diesels, I would say very similar to Benz diesel in quality now. Maintenace is key and a careful owner for long life. They are turbo charged...
Reply #5August 31, 2006, 12:12:45 pm
jamesdemien
  • 7
« Reply #5 on: August 31, 2006, 12:12:45 pm »
Thats awsome... my 05 only has 26k miles on it so i should be able to go a while longer...[/quote]
If you got caughtDriving While Intoxicated in Missouri or got a MO Speeding Ticket then check these out.
Reply #6November 29, 2006, 01:11:34 pm
Holeshot
  • 33
« Reply #6 on: November 29, 2006, 01:11:34 pm »
My wife's '00 Jetta TDI has ~287k on the clock and runs like a top (better than my '98 NB TDI with less than 1/2 that mileage...).
We bought it from the original owner and it was used to make ~150mi daily round trips across the interstate for commuting.
Properly maintained, I don't see why they couldn't easily go 600k mi.
There's a guy from San Francisco on the TDIClub forums with a white Golf TDI with something like 700k mi.  I met him at last year's TDI Fest - heck of a nice guy and the car was absolutely flawless.
Later,
Matt
'94 Dodge Ram 2500 4x4 - 12-valve Cummins, NV5600 6spd, SBC Con FE clutch, EDM injectors, etc. ~400rwhp, Isspro EGT/100psi boost gauges
'98 VW NB TDI - not stock by any means, but still pretty tame.  TDI-M candidate :cool:
'00 VW Jetta TDI - wife's 300,000+mi daily driver
