Author Topic: power steering pump mounting. differences between gas &  (Read 3055 times)
August 07, 2006, 08:10:45 am
anarchyx34
« on: August 07, 2006, 08:10:45 am »
I'm trying to mount up my power steering pump, from what I can tell I need a spacer between the pump and pulley, but I cant figure out if the bracket or the pulley itself is different. Anyone have experience with this?
Reply #1August 07, 2006, 07:34:29 pm
« Reply #1 on: August 07, 2006, 07:34:29 pm »
I can tell you from experience its a bit of a PITA trying to get the PS pump + bracket on.  If there was an easier way I would love to know for next time.. (assuming there is going to be a next time  :lol:)
Are you swapping PS pumps with a gasser?
Reply #2August 07, 2006, 07:54:02 pm
« Reply #2 on: August 07, 2006, 07:54:02 pm »
imo power steering is extremely unnecessary for mk1 and mk2 cars, unless ur handicapped or something
Reply #3August 07, 2006, 09:11:36 pm
« Reply #3 on: August 07, 2006, 09:11:36 pm »
Quote from: Trev0rbr
true that.  I hate PS.  just another way to rob HP from an already low hp engine!
Reply #4August 07, 2006, 09:30:30 pm
anarchyx34
« Reply #4 on: August 07, 2006, 09:30:30 pm »
No, just lazy, and I do a lot of paralell parking in tight spaces. I've actually not had power steering on this car since I got it (pump was no good), and I think it sucks. Besides power steering only robs power when you're actually turning.
Reply #5August 08, 2006, 07:58:02 pm
coke
  • 254
« Reply #5 on: August 08, 2006, 07:58:02 pm »
I used a P/S pump from a gas model, stole the bracket too. I have noticed my pulley is slightly out of line, barely noticable other than the fact it chews up belts.
Reply #6August 08, 2006, 09:25:53 pm
anarchyx34
« Reply #6 on: August 08, 2006, 09:25:53 pm »
Actually thanks for the reply. I wasnt sure if I could use the gasser's brackets. There IS however a spacer that's supposed to go inbetween the pump and the pulley for the diesel, and that's probably why yours is a little out of alignment.
Reply #7August 10, 2006, 06:13:42 pm
« Reply #7 on: August 10, 2006, 06:13:42 pm »
Quote from: anarchyx34
the ps pump is like a hydraulic pump.  It will build to a certain pressure and once that pressure is realized, a valve opens so that the pressure doesnt go any higher.  It does rob hp even when not turning, even if only a very very small amount.  (also hurts the revvability)
Reason I say this is because I have experience with both.  PS is nice, but I would prefer not to have it.  Just another thing to break right?  :lol:
(i had a high pres p/s line break on an audi 5k... 400 dollar dealer hose. luckily i found one at the wreckers!)
Reply #8August 10, 2006, 08:44:43 pm
anarchyx34
« Reply #8 on: August 10, 2006, 08:44:43 pm »
Try paralell parking on some of these tiny NYC streets into a spot about 3 inches larger than your car :). Its like this, move 3 inches, turn wheel full lock, move another 3 inches in the other direction, turn wheel full lock again, repeat... :)
