A1 GTI Air dam lip
Topic: A1 GTI Air dam lip (Read 13945 times)
May 12, 2004, 09:34:43 pm
fspGTD
A1 GTI Air dam lip
May 12, 2004, 09:34:43 pm »
To help protect against cone-hits, I installed a lower lip on the airdam of my Rabbit autocrosser. It's off a A3 Golf, and I installed it by pop-riveting it to the bottom of the Westmoreland GTI airdam. I also reinforced the bottom edge of the airdam with some aluminum sheet, which is braced against the lower radiator support and stops the airdam from flexing when I run over cones. Should be the last time the paint cracks on it from the flexing. Now it's gonna be "Watch out cones - here I come!!!"
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
May 12, 2004, 10:58:55 pm
fspGTD
A1 GTI Air dam lip
May 12, 2004, 10:58:55 pm »
You got that right... but at the same time, if you're not occasionally hitting a cone every now and then, you're not pushing the limit to the max. It's good to be able to do this without damage to the car. Can't wait to try it out!
Jake Russell
Dieselicious
May 19, 2004, 08:07:49 pm
Dr. Diesel
Authorized Vendor
cone muncher
May 19, 2004, 08:07:49 pm »
you should rig up a large-scale hedge trimmer along the front of the airdam. So, rather than knocking over the cones, it'll just trim the tops off, thereby leaving them standing. Cut the corner, and not get docked time!! perfect!
May 22, 2004, 06:24:36 pm
fspGTD
A1 GTI Air dam lip
May 22, 2004, 06:24:36 pm »
:lol: :lol: :lol:
Jake Russell
Dieselicious
A1 GTI Air dam lip
