Author Topic: oil cooler leaking  (Read 4318 times)
July 13, 2006, 06:48:25 pm
insdtanoodles
  • 148
oil cooler leaking
« on: July 13, 2006, 06:48:25 pm »
My oil cooler has been leaking for along time and I think I am going to do something about it. Right now it leaks from between the part where to coolant flows through and the top part where the turbo oil line screws into. Can the oil cooler be taken apart and put a gasket in there to stop the leaks? or is there anything I can do to stop it, I dont really want to spend 120 dollars for a new one. thanks
1996 vw jetta AAZ
Reply #1July 13, 2006, 09:24:04 pm
oil cooler leaking
« Reply #1 on: July 13, 2006, 09:24:04 pm »
is your oil/coolant leaking? or mixing?
Reply #2July 14, 2006, 02:27:37 am
insdtanoodles
  • 148
oil cooler leaking
« Reply #2 on: July 14, 2006, 02:27:37 am »
I havent noticed any mixing, just leaking oil.
1996 vw jetta AAZ
Reply #3July 17, 2006, 08:14:40 am
wyldman
  • 403
oil cooler leaking
« Reply #3 on: July 17, 2006, 08:14:40 am »
There is a seal in there that commonly leaks,especially if the unit is not real tight.
Remove filter,and remove stud\nut to lower cooler assy.Replace O-ring and reassemble.
(416)565-7282
