General Information
Troubleshooting
Replacing headgasket
Topic: Replacing headgasket (Read 4131 times)
June 01, 2006, 04:17:15 pm
firestorm13666
June 01, 2006, 04:17:15 pm »
Well now that i found a lower timing cover i can get to other things now.I have a few qestions on this mostly about parts.Should i get a 1.6 or a metal 1.9 gasket?Also should i use any kind of sealent and if so on what parts of the gastket?I was thinking of using the copper spray on kind.I will be geting the parts to do the job form PartsPlace.Thanks for any help.
June 01, 2006, 05:42:22 pm
firestorm13666
June 01, 2006, 05:42:22 pm »
Would it be ok to use a fel-pro gasket?
June 01, 2006, 07:11:47 pm
June 01, 2006, 07:11:47 pm »
go with the 1.9 metal hg. you won't be dissapointed
I think some other people on here have used the copper spray... I doubt it will hurt anything if applied properly.
June 02, 2006, 08:42:35 pm
firestorm13666
June 02, 2006, 08:42:35 pm »
I won't be able to get this done right away and i am in need of a car.So i was wondering how long could i get away with driving it with the blow head gasket?I do not plan to do this but i might have to.And there is not coolant in the old or oil in the coolant yet.Also the wire to the stop solenoid came out of the connector.Any ideas on how i can repair this?Thanks
General Information
Troubleshooting
