Author Topic: 10psi lift pump for 1.9TD too high?  (Read 3296 times)
May 23, 2006, 05:45:37 pm
evangelos1234
« on: May 23, 2006, 05:45:37 pm »
hi all,
is a 10psi lift pump for 1.9TD too high that wil be pushing veggie only. this pump would be for my 96 Jetta with the 1.9 Turbo Diesel not the TDI.
btw i live in a very cold climate (Montreal, Canada)
thanks
Reply #1May 24, 2006, 06:22:24 am
« Reply #1 on: May 24, 2006, 06:22:24 am »
the pump would help to push the thick veggie oil through the pump (put less load on it).  I personally would not see a problem with 10 psi.  Getting 10 psi out of veggie might require a pretty powerful pump though, considering how viscous it is.
you might want to tighten your lines too... since when the demand is lowered the pressure could spike such as in deceleration.  and to just plain ensure no leakage :)
Reply #2May 24, 2006, 08:11:25 am
Hey
  • 339
« Reply #2 on: May 24, 2006, 08:11:25 am »
you won't get any big pressure... the fuel or veggie will pass free and come back by the return lines!  :wink:
Reply #3May 24, 2006, 10:55:22 am
vwmike
  • 1158
« Reply #3 on: May 24, 2006, 10:55:22 am »
While we're on the subject, has anyone used a stock MK3 2L pump as a lift pump and if so how was pressure?
Reply #4May 24, 2006, 05:21:52 pm
DVST8R
  • 535
« Reply #4 on: May 24, 2006, 05:21:52 pm »
Malone is... was... will be agian.   :P  He can chime in but from what I rember there was never an issue and it sure made priming a pump quick and easy.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #5May 24, 2006, 06:01:06 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #5 on: May 24, 2006, 06:01:06 pm »
It was a MK3 1.8L lift pump and I don't know the specs.. I had the PSI/cc numbers but I forgot them now.
The lift pump was fine although I used it for only 10,000km, or max. 5,000km per injection pump.
I'm not sure if the MK3 2.0L lift pump is much different.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #6May 24, 2006, 11:22:06 pm
vwmike
  • 1158
« Reply #6 on: May 24, 2006, 11:22:06 pm »
I think the CL pump is something like 1.6 bar according to Etka whereas the 2L pump is supposed to be 3 bar. I'm curious what kind of pressure there would be at the pump inlet with the pump dead ended into it and if enough excess fuel can bypass back to the tank. I don't want to see fuel pressure pegged at the pump inlet and go through in-tank pumps daily....but since it's there it would be nice to use it and possibly see some benefit from it. Otherwise, I need to find a TD or TDI tank pickup but nobody has chimed into my wanted ad to say they had one.
Reply #7May 25, 2006, 04:12:47 am
vwmike
  • 1158
« Reply #7 on: May 25, 2006, 04:12:47 am »
I just looked at the ACC (CL) pump is 1.2 bar and the ABA (2L) pump is 3 bar.
