Author Topic: NA31X vs NA34X  (Read 2484 times)
May 20, 2006, 07:17:28 pm
sethyboy85
  • 284
NA31X vs NA34X
« on: May 20, 2006, 07:17:28 pm »
I am trying to find out some more information on the NA31X I have found that it was used on Turbo Mercedes applications and should have a 155bar breaking pressure but cannot confirm this, I am in the process of either buying NA34X injectors or trying out a set of 31 just need to find some more information.
any help appreciated, will try to find a MB forum I am part of and ask the same question.
thanks
Seth
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1May 20, 2006, 07:25:14 pm
sethyboy85
  • 284
NA31X vs NA34X
« Reply #1 on: May 20, 2006, 07:25:14 pm »
NA31X fits motor 617.952 3.0l 81-85 Turbo Diesel
hmm
also when I look up NA34X on some sites it pulls up a injector but only lists D1000-88785 which also comes up everytime I pull up a 31X
does this mean same injector as far as breaking pressure?
Reply #2May 25, 2006, 06:36:56 pm
sethyboy85
  • 284
NA31X vs NA34X
« Reply #2 on: May 25, 2006, 06:36:56 pm »
well anyway, NA34X seems to work fine in a VW... I got them yesterday and installed them tonight since my dad needed good injectors in his car and I have injectors all apart in our garage, I told him wait 30min and I will have good injectors for you.
so we swapped my injectors and the car starts fine, I might have to get the timing slightly advanced since they are 155bar NEW not slightly worn out. drives okay but I only have an ECO pump on the car right now, will report back on smoke and power. I have a 1/4 uphill I test stuff, which is on my way home from work.
