Author Topic: GTD intercooler  (Read 15044 times)
May 17, 2006, 09:17:48 pm
1985JettaTD
GTD intercooler
« on: May 17, 2006, 09:17:48 pm »
does anyone know of a part number for the intercooler out of the euro GTD. i want to try to get a hold of everrything for it. i am working at a vw dealer right now and they can get me imported part real cheap.
thanks for the help
Reply #1May 17, 2006, 10:16:43 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
GTD intercooler
« Reply #1 on: May 17, 2006, 10:16:43 pm »
Do a lookup of the rallye. It had the same setup for the shrouding and whatnot. I'm pretty sure it had the same intercooler.
Reply #2May 17, 2006, 10:59:19 pm
vanagonturbo
  • 639
    • Fine Tuning
GTD intercooler
« Reply #2 on: May 17, 2006, 10:59:19 pm »
Umm yeah, the rallye has a totally different intercooler.
The GTD is GTD specific. It sits near the battery and is oriented face up.
Although, if you can get a rallye intercooler, that would be even better, just make sure you are planning some serious boost to make it work.
Try looking at www.ebay.de and look for "Ladeluftkuhler". Unfortunately, I dont know how to make the umlaut (sp) for the second "u". You will need to have that for a successful search.
Reply #3May 18, 2006, 12:45:54 am
GTD intercooler
« Reply #3 on: May 18, 2006, 12:45:54 am »
Quote from: vanagonturbo
you mean "Ladeluftkühler" ? keystroke ALT-0252  :D
Reply #4May 18, 2006, 02:29:40 am
regcheeseman
  • 714
GTD intercooler
« Reply #4 on: May 18, 2006, 02:29:40 am »
I'm selling one from a GTD.
No shrouds though - the parts are obsolete to.
Reply #5May 18, 2006, 05:41:30 am
HP
  • 225
GTD intercooler
« Reply #5 on: May 18, 2006, 05:41:30 am »
The RA/SB IC looks like the GTI G60 one with air cond.
The Rallye has an FMIC or SMIC (don't really know the exact setup).
edited
Reply #6May 18, 2006, 11:58:37 am
dubCanuck1
  • 279
GTD intercooler
« Reply #6 on: May 18, 2006, 11:58:37 am »
Is this not the same setup as the GTD? It's a quote from vwvortex's featured car "the color of money" http://vortex3.rely.net/artman/publish/article_313.shtml
The component that really sets this engine ahead of other G60s has to be the VW Motorsport intercooler and air duct that was originally developed for race spec Rally Golfs in the late ‘80s. Since the piece was developed as part of the factory Motorsport program, the fitment is clean and looks as if it was there the day the car rolled off the assembly line. Air is intended to flow under the driver's side headlight and into the duct, though NGP chose to improve on that by fitting the car with a custom fiberglass hood with built-in air scoop.
Reply #7May 18, 2006, 11:59:44 am
dubCanuck1
  • 279
GTD intercooler
« Reply #7 on: May 18, 2006, 11:59:44 am »
Oh, and where can I find one?
Reply #8May 18, 2006, 12:40:16 pm
vanagonturbo
  • 639
    • Fine Tuning
GTD intercooler
« Reply #8 on: May 18, 2006, 12:40:16 pm »
There are a few things wrong with that.
The intercooler is from a GTD. The car is not even a rallye.
If you would like, I can take a pic of the Rallye Golf intercooler that I have sitting on my shelf. It is about 2.5 times the size of the GTD unit. It is a front mount unit that sits in front of the radiator.
It seems that someone says they have the intercooler a few posts up.
Reply #9May 18, 2006, 01:42:29 pm
HP
  • 225
GTD intercooler
« Reply #9 on: May 18, 2006, 01:42:29 pm »
I really don't know where did the man get the "Motorsport" idea. :?
That's a G60. It's the stock IC from the air contitioned versions.
It just happens the IC looks pretty much like a RA/SB one, but I belive they are actually different. The inlet and/or outlet is the difference. :idea:
So,... it's not.
edited
Reply #10May 18, 2006, 03:40:30 pm
vanagonturbo
  • 639
    • Fine Tuning
GTD intercooler
« Reply #10 on: May 18, 2006, 03:40:30 pm »
805c and 805d
You are correct sir. I must say that they look very similar. However, I would be very curious as to how the AC models utilize the cooler that I have and swtill have space to fit the condenser.
I would be more apt to believe that the IC in the pic is one used on models that HAVE AC.
either way, thanks for the info! Learn something new every day.
Reply #11May 18, 2006, 04:57:57 pm
HP
  • 225
GTD intercooler
« Reply #11 on: May 18, 2006, 04:57:57 pm »
Yes, that is precisely it. Thank you for the correction.
My bad..  :roll:
Reply #12May 18, 2006, 10:23:30 pm
LeeG
  • 401
GTD intercooler
« Reply #12 on: May 18, 2006, 10:23:30 pm »
Group buy?!  I'm in!!
I've been looking for a while.  I'd really rather buy the whole works so its a bolt on deal.
Below is some stuff I googled up a while back:
Looks like a fatory parts diagram, no numbers though:
http://www3.telus.net/greenough/images/gtdicdiagram.jpg
A2 GTD intercooler is 11.5" wide, 2.5" thick and 9" tall. The part
number is 191 145 805A and it is manufactured by Langerer and Reich.
link I found:
http://scirocco.cs.uoguelph.ca/gtd/about_gtd.htm
'97 Passat TDI
Reply #13May 19, 2006, 01:51:12 am
regcheeseman
  • 714
GTD intercooler
« Reply #13 on: May 19, 2006, 01:51:12 am »
I've got ETOS here with all the part numbers on it - which do you need?
Reply #14May 20, 2006, 10:08:02 am
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
GTD intercooler
« Reply #14 on: May 20, 2006, 10:08:02 am »
GTD intercooler is standard type, and G60 is crossflow type, that is the difference...
Excuse me on my bad English
