Author Topic: GTD intercooler  (Read 15035 times)
Reply #15May 20, 2006, 12:16:36 pm
GTD intercooler
« Reply #15 on: May 20, 2006, 12:16:36 pm »
i wonder if standard or cross flow is better,  cross flow probably flows much better...
Reply #16May 20, 2006, 12:18:30 pm
GTD intercooler
« Reply #16 on: May 20, 2006, 12:18:30 pm »
oh, lol i read on a site off google, definetly cross flow, maybe i'll use my passat intercooler instead of my audi 4k or 5k one.
Reply #17May 20, 2006, 07:51:26 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
GTD intercooler
« Reply #17 on: May 20, 2006, 07:51:26 pm »
Crossflow is better and I don't recall see any aftermarket IC in standard type....
Excuse me on my bad English
Reply #18May 25, 2006, 03:43:24 pm
scopefrfd
  • 289
GTD intercooler
« Reply #18 on: May 25, 2006, 03:43:24 pm »
I have one for sale here in the states...email me if interested
Reply #19June 08, 2006, 11:24:43 am
avocado_tom
GTD intercooler
« Reply #19 on: June 08, 2006, 11:24:43 am »
Quote from: Trev0rbr
Ha!  Well, let me know if you want to get rid of that Audi one.  :)
    -avocado in Pittsburgh, PA
Reply #20September 08, 2006, 06:06:42 pm
cubevandude
  • 11
Factory Diagram of GTD intercooler setup
« Reply #20 on: September 08, 2006, 06:06:42 pm »
http://scirocco.cs.uoguelph.ca/gtd/about_gtd.htm
 :arrow: Factory Diagram of GTD intercooler setup.
Reply #21September 08, 2006, 08:55:46 pm
Kudagra
  • 738
    • www.no-coast.com
GTD intercooler
« Reply #21 on: September 08, 2006, 08:55:46 pm »
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #22September 10, 2006, 03:11:02 pm
ezekiel
  • 147
GTD intercooler
« Reply #22 on: September 10, 2006, 03:11:02 pm »
after going into the intercooler, where the hell does the air go?
Reply #23September 10, 2006, 04:56:55 pm
GTD intercooler
« Reply #23 on: September 10, 2006, 04:56:55 pm »
into the intake manifold
Reply #24September 11, 2006, 07:12:40 pm
ezekiel
  • 147
GTD intercooler
« Reply #24 on: September 11, 2006, 07:12:40 pm »
Quote from: burn_your_money
I really hope that was a smartass comment :p
the air coming in over the headlight across the intercooler appears to dead end right on the engine, not really what I'd call ideal for flow.  Not to mention the heat soak issues.
Reply #25September 11, 2006, 07:30:50 pm
GTD intercooler
« Reply #25 on: September 11, 2006, 07:30:50 pm »
yeah I forget the ":P"
Reply #26September 11, 2006, 09:57:51 pm
QuickTD
  • 1156
GTD intercooler
« Reply #26 on: September 11, 2006, 09:57:51 pm »
The air would dump into the under hood cavity above the transaxle, which should be a fairly low pressure area. I expect the pressure differential across the core would be much same as a front mount, though the core size is much smaller. The heat soak issues with the GTD setup are real though.
 I run a similar setup to the GTD's on my Mk3 but it uses a thicker single pass core and a larger intake duct. The effectiveness is decent. Its difficult to get IAT's above 40ºC with 17psi of boost. IC inlet temps can exceed 115ºC.
There are many ways to mount an intercooler, the front mount allows the largest physical size but may not always the best for airflow, especially if you have AC condensor, IC and rad all stacked up. Some world rally teams mount rad and IC angled in sort of a V shape to avoid the pitfalls of layering, requires lots of sheet metal work and an "extractor" hood. I've always thought that the the twin side mount with vented fender linders from the audi TT might be the hot, er cool ticket for an AC equipped car.  :D
