Author Topic: Fuel Pump Question  (Read 2880 times)
May 05, 2006, 04:41:59 am
Busdriver
  • 22
Fuel Pump Question
« on: May 05, 2006, 04:41:59 am »
:?: Will a 1.6 TD fuel pump work on an AAZ 1.9 TD engine :?:
John Koloski
98 Jetta TDI
90 Vanagon 1.9TD AAZ
occasional biodiesel brewer
Reply #1May 05, 2006, 05:32:12 am
HP
  • 225
Fuel Pump Question
« Reply #1 on: May 05, 2006, 05:32:12 am »
btw, I beg to ask the same, but vice-versa :!:
Reply #2May 05, 2006, 07:04:13 am
QuickTD
  • 1156
Fuel Pump Question
« Reply #2 on: May 05, 2006, 07:04:13 am »
The 1.6 and 1.9 pumps are mechanically interchangeable up until the '95 model year. After '95 the 1.9TD pump has a different diameter where it fits through the bracket, a slightly longer shaft and an adjustable pulley instead of slotted mounting holes for timing adjustment. These pumps can still be used on the 1.6TD (and 1.6 pumps can be used on '95 and up 1.9)  but you need to swap the whole pump mounting bracket and pulley.
The 1.6TD pump will be set up for slightly lower full power injected quantity (68hp vs 75hp). The 1.6TD pump also has less power potential due to lower camplate lift. Aside from that the engine should run fine.
Reply #3May 05, 2006, 07:21:52 am
HP
  • 225
Fuel Pump Question
« Reply #3 on: May 05, 2006, 07:21:52 am »
thanks
Reply #4May 05, 2006, 02:56:11 pm
andy2
Fuel Pump Question
« Reply #4 on: May 05, 2006, 02:56:11 pm »
Quote from: QuickTD
Correction,the 1.6 pump has the same housing ID as the early 1.9 pumps however the 1.6 pump's housing has a shorter nose than the early 1.9 pump's housing(up to 95).For this one and only reason the pumps cannot be changed.If you were to put the 1.6 pump brackets on the 1.9 you could then use the 1.6 pump on any 1.9(93-97).
Working backwards putting a 1.9 pump on a 1.6 you would have to put the 1.9 pump bracket on the 1.6 for it to work.
Reply #5May 05, 2006, 04:14:27 pm
QuickTD
  • 1156
Fuel Pump Question
« Reply #5 on: May 05, 2006, 04:14:27 pm »
My mistake, didn't realize the offset was different on all 1.9 pumps. They kinda look the same when stored in a pile on the floor... :D
