Author Topic: Master cylinder reservoir leaking suddenly  (Read 5824 times)
April 26, 2006, 07:27:18 pm
shwartzbewithyou
« on: April 26, 2006, 07:27:18 pm »
I lost brake pressure today at a stop light so I pulled into a gas station and checked and I have a massive leak where the reservoir meets that master cylinder.  I looked on all the parts websites and they sell a grommet for $2.00 or so each.  Is this all that holds the reservoir onto the master cylinder?  Because I wiggled the reservoir and it was loose and it leaked worse when I moved it.
So I'm just checking, is something under the reservoir broken or do I just replace the grommets and press it back into place?
Reply #1April 26, 2006, 07:48:01 pm
wyldman
  • 403
« Reply #1 on: April 26, 2006, 07:48:01 pm »
The master cylinder reservoir musthave broken,as the seal rarely fails.
Try to pop the reservoir out and see what you find.
(416)565-7282
Reply #2April 27, 2006, 05:50:06 am
shwartzbewithyou
« Reply #2 on: April 27, 2006, 05:50:06 am »
I will but I have to drive the car on Monday.  So that means I take it apart Saturday, and fix either Saturday or Sunday.  Yikes.  I hope I get parts in time.
Reply #3April 27, 2006, 10:10:55 am
TDForNow
  • 131
« Reply #3 on: April 27, 2006, 10:10:55 am »
Yes, those seals are all that hold the reservior in. There's no pressure there, just gravity and return. The (@1/4") nipples molded in to the bottom of the res. snap into the grommets on the master cyl. They're plastic just like the res. and can break easily if aged.
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #4April 30, 2006, 07:08:01 am
shwartzbewithyou
« Reply #4 on: April 30, 2006, 07:08:01 am »
So I pulled it off and found the the problem is a little bit more difficult to fix than I thought.  It's the top of the master cylinder that's crusting away in it's old age.  So I had clean it up and hope for the best.  I pulled off the grommets and the one tore which sucks because I couldn't get new ones on such short notice.  So out came the gasket maker.  I cleaned up the top of the master cylinder with some rough sandpaper (oddly enough I can't find a file when I need one), and then spread some more gasket maker on the underside of the grommets.  I placed the grommets back in and let them sit overnight before puting any real pressure on them.  The next day i put the reservoir back on and put a large gear clamp over the top of it to hold pressure down on the gasket maker.  It's holding completely dry the next day after a couple of drives.
So far so good.
I know the pro's on here are dissapointed in me, get over yourselves, it's a temp fix. :lol:
