Author Topic: Leaky AAZ valve cover cure ????  (Read 3274 times)
July 13, 2017, 12:19:09 pm
Dubdoc
« on: July 13, 2017, 12:19:09 pm »
Does anyone know of a surefire cure for the always-leaky AAZ valve cover ???
« Last Edit: July 13, 2017, 12:24:15 pm by Dubdoc »
Reply #1July 14, 2017, 12:17:51 pm
Re: Leaky AAZ valve cover cure ????
« Reply #1 on: July 14, 2017, 12:17:51 pm »
aluminum valve cover i'd say, but i think i have seen you say that you are opposed to that.
they always need a dab sealer around the bump for the cam
Reply #2July 14, 2017, 11:37:18 pm
« Reply #2 on: July 14, 2017, 11:37:18 pm »
I put a G60 valve cover on mine.
Reply #3July 23, 2017, 06:39:57 am
Gizmoman
  • 1301
« Reply #3 on: July 23, 2017, 06:39:57 am »
I'd do the G60 if you can drill and tap without issue.
My fix was a thin bead of "The Right Stuff" on both sides of a new gasket. It really is fantastic stuff. Just be sure you're done taking the cover off for a while.
Zero leaks now - sweet.
I also had a leak at the hockey puck grommet (50° engine). I found a tighter grommet in my box of crap that sealed it.
