Author Topic: VW 1.6 NA to Turbo swap! Questions and Progress.  (Read 49495 times)
March 30, 2017, 10:32:02 am
Tmarkle
  • 153
« on: March 30, 2017, 10:32:02 am »
So I have acquired nearly all the parts to turbo my 1.6, but I still need an oil feed line for the turbo. I acquired a stock 1.6 TD oil filter housing and a K03 turbo, so what fitting do I need on either side of the line for the feed? I'll also post progress of my project here. Once I have the feed line I will start putting everything together. Any other tips for the swap will be greatly appreciated!!!
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #1March 31, 2017, 03:28:00 pm
vic003
  • 508
Re: VW 1.6 NA to Turbo swap! Questions and Progress.
« Reply #1 on: March 31, 2017, 03:28:00 pm »
I don't understand your question.
IMO, you should better use braided SS oil feed line. I can't remember the dimensions of the fitting, maybe 10x100 and standard conical seal, maybe 60° cone.
I bought them to my local store in France specialised in pressure hoses made to measure.
I will need approx 80 to 100cm and bought them for 50$, found it cheap for the quality compared to the crap stock feed line.
Envoyé de mon PLK-L01 en utilisant Tapatalk
Reply #2March 31, 2017, 08:22:47 pm
Gizmoman
  • 1301
« Reply #2 on: March 31, 2017, 08:22:47 pm »
There should be no pressure on the line to speak of. Just be sure the hose you use is rated for oil and can withstand 500F,
I have no idea what fittings you'll need. "push-on" type with the proper ends for you engine and turbo will do fine with some good clamps.
Reply #3April 01, 2017, 07:39:51 am
vic003
  • 508
« Reply #3 on: April 01, 2017, 07:39:51 am »
No no no, he is talking about the oil FEED line, not the return line.
Feed line have to handle engine oil pressure.
Reply #4April 01, 2017, 08:12:16 am
Gizmoman
  • 1301
« Reply #4 on: April 01, 2017, 08:12:16 am »
I know it's a feed line, but worst case the pressure should not be over 90 psi. Nearly any oil line hose can handle that easily (doesn't need to be wire braid). However, the connections should be rock solid for sure. Use SS braid if your going for the bling, but it's not necessary.
Another option is soft steel tube (like large diameter brake line) with proper end connections. That's what my stock feed line is on my AAZ.
Reply #5April 01, 2017, 10:11:14 am
« Reply #5 on: April 01, 2017, 10:11:14 am »
I've made several different custom supply lines from 5/16" steel tubing bent to fit.  Mcmaster sells 5/16" compression ferrules that work with the 5/16" steel tubing and the stock VW compression fittings.  Make sure to add an anti-vibration clip or two.
Reply #6April 02, 2017, 09:41:59 pm
  • 2931
« Reply #6 on: April 02, 2017, 09:41:59 pm »
 Yep, easy bend brake line.
Reply #7April 03, 2017, 02:05:49 pm
Tmarkle
  • 153
« Reply #7 on: April 03, 2017, 02:05:49 pm »
Thanks everyone. A local shop here in town can build me a steel braided line pretty cheap so I'll probably go that route. I'm hopefully gunna start the project this weekend, depending on if I get the line!
Reply #8April 04, 2017, 02:50:37 pm
vic003
  • 508
« Reply #8 on: April 04, 2017, 02:50:37 pm »
Good choice, they are not so expensive, durable and practical!
Reply #9April 05, 2017, 10:25:04 am
Tmarkle
  • 153
« Reply #9 on: April 05, 2017, 10:25:04 am »
Got the feed line built today. $50 for a SS braid line and two metric to standard adapters. Should be able to get started this weekend!
Reply #10April 12, 2017, 10:30:22 am
Tmarkle
  • 153
« Reply #10 on: April 12, 2017, 10:30:22 am »
Got started on the swap last night. Removed the manifolds, swapped the oil filter flange for one with a turbo feed outlet, and welded a fitting into the oil pan for an oil drain. I'll upload photos this afternoon. Going pretty well so far. Next step will be to drill and tap the exhaust manifold for a EGT probe and the intake manifold for a boost sender.
Reply #11April 18, 2017, 02:33:32 pm
Tmarkle
  • 153
« Reply #11 on: April 18, 2017, 02:33:32 pm »
Been a while, sorry. Got the swap done! I'm happy with the nice torque improvement. Took Longer than I expected, but it was worth it. How do I post pictures? LOL sory dumb question I'm sure.
Reply #12April 18, 2017, 03:19:45 pm
Gizmoman
  • 1301
« Reply #12 on: April 18, 2017, 03:19:45 pm »
Congratulations on your achievement.
Hopefully one of the moderators can help with posting photos or you can read the FAQ
Reply #13April 19, 2017, 01:22:50 am
kljaja
  • 38
« Reply #13 on: April 19, 2017, 01:22:50 am »
What exhaust did you use? Old one made to fit td? Gear lever system doesnt hit toilet bowl?
Going fast never killed anyone, suddenly becoming stationary, thats what gets ya
Reply #14April 19, 2017, 01:11:11 pm
« Reply #14 on: April 19, 2017, 01:11:11 pm »
Easiest way to post photos by far is to install Tapatalk on your phone and do it from there... Becomes pretty straight forward that way.
