Author Topic: WTB: Vanagon five-speed transaxle code AAP  (Read 3259 times)
February 08, 2017, 08:18:34 am
foxfour
  • 12
« on: February 08, 2017, 08:18:34 am »
AAP is my first choice in a vanagon transaxle.  I'll consider other 5-spd codes.  Thanks
Reply #1February 08, 2017, 01:08:26 pm
Re: WTB: Vanagon five-speed transaxle code AAP
« Reply #1 on: February 08, 2017, 01:08:26 pm »
If you're in North America, you should consider the DX from an '83 diesel along with an R+P change to the 4.14.  Bear in mind the shifter/linkage is different as well.  Weddle also offers a 5-speed conversion for the later WBX 091/1 4-speeds (often called 094 4-speeds).
Reply #2February 08, 2017, 02:09:52 pm
foxfour
  • 12
« Reply #2 on: February 08, 2017, 02:09:52 pm »
Thank you for the suggestion, Andrew.  When I repost, as I'm not getting any hits on this or the tdiclub forum, I'll list some other trans codes that are also acceptable.  My present wbx trans is a 091/1 ABD, so it would be a candidate for the 5-spd swap.  Worth a looksee at Weddle.  Thanks again. Joe
