Basic IDI vs mTDI questions
Pages:
4
Topic: Basic IDI vs mTDI questions (Read 16064 times)
Reply #15
November 25, 2015, 07:14:54 pm
mammonista
Re: Basic IDI vs mTDI questions
Reply #15 on:
November 25, 2015, 07:14:54 pm »
what turbo, new or used, would fit the 1.6td exhaust manifold? and space is limited, I think the compressor inlet is about an inch from the van engine support member!
thanks everybody by the way
If it doesn't fit force it. If it breaks it needed replacing anyway!
Reply #16
November 25, 2015, 07:50:47 pm
RunninWild
Reply #16 on:
November 25, 2015, 07:50:47 pm »
There are 2 styles of manifolds a 4 bolt and a 3 bolt. Smaller turbo's use the 3 bolt and the bigger stock turbo's use the 4 bolt. A k14 seems to be the best blend of spooling for medium boost levels. K24 or t3 if you want to run a lot of boost.
Reply #17
November 25, 2015, 08:12:16 pm
mammonista
Reply #17 on:
November 25, 2015, 08:12:16 pm »
memory is a funny thing...it's been soooooo long ago that I did the original quantum td into the diesel van swap that I kinda forgot. Now I seem to remember that I sourced the quantum as donor car because that flavor 1.6td was oriented north/south in the engine bay and the exhaust manifold outlet was at the end instead of the middle which allowed the turbo to clear the van engine support carriers. does that sound right? it's been almost 15 or 16 years since I did the swap.
so maybe I'm better trying to fix the wastegate actuator housing on the t3. Since van-no-mo is on the heavy side (3,600 lbs.) I'm not particularly interested in a fast spool, and I know this thing will fit if I can just fix it.
Reply #18
November 27, 2015, 07:10:45 am
mammonista
Reply #18 on:
November 27, 2015, 07:10:45 am »
Okay, apparently a K14 is the way to go here. Now the challenge is to find one as inexpensively as possible with the trapezoidal exhaust gas inlet flange. They can be had for $450, rebuilt out of Germany but that seems a bit much. Any ideas?
thanks in advance
Reply #19
November 27, 2015, 11:10:05 am
Reply #19 on:
November 27, 2015, 11:10:05 am »
It was never a super common turbo in North America. AAZ cars in Canada would probably be the best bet. Try contacting CanadaCatalyst (they advertise on here)
Reply #20
November 30, 2015, 08:29:56 pm
mammonista
Reply #20 on:
November 30, 2015, 08:29:56 pm »
Bought a used K14 turbo off German Ebay tonight for $120. Will cost $60 to ship to the states. Once it arrives does it make sense to try to rebuild it, or just run it as is and hope for the best? The seller said it came off a running car and was working as it should...
Reply #21
December 01, 2015, 07:22:39 am
RunninWild
Reply #21 on:
December 01, 2015, 07:22:39 am »
If there isnt any excessive shaft play, no signs of oil leaks and the waste gate isnt seized I see no reason to rebuild it.
Reply #22
December 01, 2015, 05:19:27 pm
mammonista
Reply #22 on:
December 01, 2015, 05:19:27 pm »
okay dumb question here. how to tell if the wastegate is seized?
Reply #23
December 01, 2015, 09:25:51 pm
RunninWild
Reply #23 on:
December 01, 2015, 09:25:51 pm »
You should be able to push it open by hand and it should snap closed when you let go of it.
Reply #24
December 03, 2015, 07:07:47 am
mammonista
Reply #24 on:
December 03, 2015, 07:07:47 am »
gasket between turbo and exhaust manifold? gasket between turbo and exhaust pipe?
thanks in advance for answers
Reply #25
December 03, 2015, 07:35:38 am
RunninWild
Reply #25 on:
December 03, 2015, 07:35:38 am »
Yes you want gaskets in those places.
Reply #26
December 03, 2015, 11:15:08 am
Reply #26 on:
December 03, 2015, 11:15:08 am »
I do not use a gasket between turbo and manifold or between the turbo and the downpipe. In both cases I use a light smear of Ultra Copper and have never had an exhaust leak in more than a decade of doing so on quite a few vehicles.
Reply #27
December 03, 2015, 12:54:24 pm
mammonista
Reply #27 on:
December 03, 2015, 12:54:24 pm »
that's what i needed to know! thanks!!!
Reply #28
December 21, 2015, 06:41:33 pm
mammonista
Reply #28 on:
December 21, 2015, 06:41:33 pm »
My used K14 from Germany arrived in the mail today. Appears to be in excellent condition and I think the cost was very reasonable. $120 for the turbo on German Ebay and $35 to have it shipped to the U.S.
But I do have a couple of questions...
(pic#1) I assume the long 'pipe' is the pressure (inlet) side of the oil lube for the bearings and the outlet side (to the pan) is on the other side of the bearing housing? The only reason I ask is it was exactly opposite on my old T3 turbo...or maybe I just had it plumbed wrong!
The inlet side is a larger diameter hole than the outlet side which makes sense I guess, but if anyone knows for sure I'd appreciate the input.
(pic#2)And can the housing sides be rotated to accommodate different oil pipe and air compressor orientations by loosening the green or blue arrows and is there any downside to that?
thanks in advance!
Reply #29
December 22, 2015, 06:18:39 am
Reply #29 on:
December 22, 2015, 06:18:39 am »
Bigger hole is the drain 100% of the time
Round 2
Pages:
4
