Author Topic: How long does your oil pressure light stay on?  (Read 8872 times)
December 08, 2014, 11:59:06 am
wjdzl
  • 8
« on: December 08, 2014, 11:59:06 am »
Slowly but surely getting sucked into the diesel world, having bought a Vanagon with AAZ.
Something that's been bothering me is how long it takes for the oil pressure light to go out when starting.  If it's a warm start [the light] goes out pretty quickly, if it is a cold start, sometimes it takes 4-5 seconds?  Is that normal or should I look into switching oil weight (not sure what the PO has in there, think it's Mobil 1 Syn)  During those 4-5 seconds I feel like I can hear more valvetrain noise as it's building pressure.
Cheers!
Reply #1December 08, 2014, 06:45:18 pm
Re: How long does your oil pressure light stay on?
« Reply #1 on: December 08, 2014, 06:45:18 pm »
I see the same behavior with my AHU, currently running 15w40. Interested to see other responses here.
Reply #2December 08, 2014, 06:55:21 pm
nissannx
  • 75
« Reply #2 on: December 08, 2014, 06:55:21 pm »
1992 1.6 na. After an oil change about 5 sec. After a cold start. Maybe at most 2 sec
Reply #3December 08, 2014, 09:18:21 pm
« Reply #3 on: December 08, 2014, 09:18:21 pm »
I've got a digital gauge attached to the head (that's the switch that flashes the oil pressure light at under 2000 engine RPM). The head switch triggers at about 0.1 bar. I do usually see that much within a couple of seconds at current temperatures but it takes more like 15 seconds for oil pressure to completely stabilize.
Reply #4December 09, 2014, 05:19:51 am
« Reply #4 on: December 09, 2014, 05:19:51 am »
I have both the stock system and an autometer electric gauge. I get my light to go out while it is cranking or less than 1 second. I also see with cold 10w-30 around 15lbs before it lights. I did have the crank machined and new KS bearings when I rebuilt it.
Reply #5December 09, 2014, 08:21:09 am
« Reply #5 on: December 09, 2014, 08:21:09 am »
Are you measuring at the head or at the filter flange?
Reply #6December 09, 2014, 09:08:57 am
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #6 on: December 09, 2014, 09:08:57 am »
Newly built 1.6d with hydro head and matching mk2 oil pump, turns off after just a couple seconds of cranking.
.:Sent by pneumatic tubes
Reply #7December 09, 2014, 09:12:22 am
TimpanogosSlim
  • 590
« Reply #7 on: December 09, 2014, 09:12:22 am »
Fwiw there are a variey of different oil pressure switches. Since i converted from mech to hydro head, i did some research and put an 0.25 bar in the head and a 1.4 bar in the filter flange.
Iirc 0.1 bar is the spec for mech heads.
« Last Edit: December 09, 2014, 09:24:30 am by TimpanogosSlim »
Reply #8December 09, 2014, 05:54:29 pm
« Reply #8 on: December 09, 2014, 05:54:29 pm »
I measure from the cylinder head.
Reply #9December 09, 2014, 07:05:39 pm
air-cooled or diesel
« Reply #9 on: December 09, 2014, 07:05:39 pm »
my ahu the oil light goes right out. on my older (mk2) it takes a second or just a little longer.
in an older engine/used car changing oil can be a problem in its self, if po had one thing (oil) in car use only that oil; changing brand can be a problem. weight can too i believe.
sounds like you have a problem there though. if po used 5w-40 mobile1 change back to this; if you still have a late light, next you likely test sensors.
Reply #10December 09, 2014, 07:18:18 pm
« Reply #10 on: December 09, 2014, 07:18:18 pm »
How long do you have to crank to have it start? Mine usually lights off on the second bump of the starter - nowhere near enough time to build up any pressure if it's been sitting overnight say. I get your results if I come out of the grocery store or something like that where it has been sitting for less than an hour.
Reply #11December 09, 2014, 09:41:02 pm
« Reply #11 on: December 09, 2014, 09:41:02 pm »
I am running around 17:1 compression, if it is cold maybe 5 turns of the starter, but the oil is cold so it shoots pressure right up. If it is warm it will light first turn and have oil pressure right about then...maybe a thousand one count.
Reply #12December 10, 2014, 02:11:54 am
Renax
  • 90
« Reply #12 on: December 10, 2014, 02:11:54 am »
I have a AAZ powered Caravelle (euro vanagon). Running on mobil 5w50 currently. If i glow a long time, it fires up at first crank, then the light stays on 1-1,5 seconds.
If its cranking 2-3 times before start i never see the oil light... hot starts i never see the light...
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
Reply #13December 10, 2014, 05:13:02 am
sgnimj96
  • 185
« Reply #13 on: December 10, 2014, 05:13:02 am »
         I installed a mechanical gauge (using a metric T-fitting like this one http://www.jegs.com/i/VDO/918/240-850/10002/-1?CAWELAID=1710621319&CAGPSPN=pla&catargetid=230006180000848799&cadevice=c&gclid=CKnboP7Du8ICFfPm7AodOhEAOg) and have the light as well
  note: my mechanical gauge (sunpro) is 1/8NPT but it went into the metric fitting without much trouble
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #14December 10, 2014, 09:53:10 am
TimpanogosSlim
  • 590
« Reply #14 on: December 10, 2014, 09:53:10 am »
Yeah 1/8 NPT and m10x1 are almost the same thread. Almost.
