Author Topic: How long does your oil pressure light stay on?  (Read 8848 times)
Reply #15December 10, 2014, 10:43:34 am
air-cooled or diesel
Re: How long does your oil pressure light stay on?
« Reply #15 on: December 10, 2014, 10:43:34 am »
   note: my mechanical gauge (sunpro) is 1/8NPT but it went into the metric fitting without much trouble
Yeah 1/8 NPT and m10x1 are almost the same thread. Almost.
always err on the side of being exact/esp. with npt threads.
Reply #16December 10, 2014, 11:51:58 am
« Reply #16 on: December 10, 2014, 11:51:58 am »
I would not thread an NPT fitting into the head as it will distort the threads in the head and very possibly make the head unable to accept a stock sender without leaking.  I would have no qualms at all about threading an NPT into a bronze 8mm fitting or threading 8mm into a bronze 1/8"npt.  I have done so several times without issue and if I did ever happen to have an issue it would be very easy to replace the fitting and sender.
Reply #17December 10, 2014, 10:07:02 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #17 on: December 10, 2014, 10:07:02 pm »
So, with almost 25 miles logged on my build, I am comfortable with the fact that with a pressure sender in the filter flange, I see around or in excess of 80psi (per fake vdo sender and real vdo gauge) when the oil is cold, and after the oil is uniformly heated it will drop to 35 or so when idling and surge back around 80psi under power.
and it's boring. And I'm pretty sure the idiot switch on the flange does a plenty fine job of letting me know that i have completely lost oil pressure. I have tested it twice now and the local streets are still oily.
I love metrics. I respect and admire metrics. My life is dedicated to quality assurance so I'm all about measuring and verifying. I feel like my oil pressure metrics in the coupe aren't really telling me something i am interested in knowing.
Is there a downside to simply replacing the oil pressure switch in the head with a (real VDO) oil pressure sender and letting that side of the warning system go hang?
or should i install a tee. which might have to be a tee and a bushing.
« Last Edit: December 10, 2014, 10:09:00 pm by TimpanogosSlim »
Reply #18December 10, 2014, 10:25:39 pm
« Reply #18 on: December 10, 2014, 10:25:39 pm »
Slim,  If you really like metrics and like them to be close to what they are then why depend on electric senders to tell you fake values.  They do sell mechanical gauges and if you pay more than 17.99 for them you might have faith in what they are tell ya.
Reply #19December 11, 2014, 07:54:49 am
« Reply #19 on: December 11, 2014, 07:54:49 am »
I disconnected my head switch years ago to install a gauge but I've kept the high pressure switch at the flange. That way I still have a working alarm system plus a gauge without having to deal with a tee. The head switch is only so valuable really - it doesn't really come in to play under normal driving, just at idle or if you happen to be lugging your engine.
Reply #20December 11, 2014, 09:30:55 am
TimpanogosSlim
  • 590
« Reply #20 on: December 11, 2014, 09:30:55 am »
I just don't really like the idea of plumbing oil through the firewall. I also doubt that the difference in accuracy is that great.
.:Sent by pneumatic tubes
Reply #21December 11, 2014, 03:38:27 pm
« Reply #21 on: December 11, 2014, 03:38:27 pm »
I'd tend to agree, I don't see electronic sensors as being all that bad, as long as you use good quality ones. Same is true for any gauge though - quality matters huge with measuring instruments.
Reply #22December 11, 2014, 09:20:13 pm
« Reply #22 on: December 11, 2014, 09:20:13 pm »
I just haven't convinced myself that electronic senders are all that good.  You have to convert a pressure ( something physical) to an electronic signal, then send that signal to a gauge that converts it either back to a mechanical or digital readout.  Can you really trust that to be accurate?  If you pay enough for the parts to be good enough to be accurate but time goes by and stuff gets out of spec.  To me the more inbetween conversions you have going the less dependable it will be.
I never worried about fuel or oil in the cab.  That is what grommets are for and that line is tough if you don't kink it.  Besides we are driving diesels, you is really going to notice the smell?
Reply #23December 11, 2014, 10:40:30 pm
TimpanogosSlim
  • 590
« Reply #23 on: December 11, 2014, 10:40:30 pm »
There's a certain leap of faith that the gauge printing is precisely relative to the motion of the mechanical needle as well.
the linearity of a transducer is relatively easy to establish. assuring correct relative motion of the needle to the dial isn't a hard engineering problem, but we really don't need a lot more than a rough measurement.
I have more faith in my ability to maintain perfect electrical connections than my ability to maintain perfect hydraulic connections. to each his own.
Reply #24December 12, 2014, 06:36:26 pm
iamdieselnutmechanic
  • 53
« Reply #24 on: December 12, 2014, 06:36:26 pm »
I use a mechanical oil and coolant gauge. The oil pressure is from the side of the head, and the coolant temp is from the front of the head.
I could not be happier with its reaction times and accuracy. I can see the coolant temps drop on the gauge from turning on the heater fan.
I use a 0w40 Rotella T6 (AHU) and I get oil pressure at the head right after the engine fires, unless it is WELL below freezing (like -4f) and then it has taken the longest of 3 seconds to start moving the needle from 0. By 4 or 5 seconds I am at full cold start oil psi at the head.
« Last Edit: December 12, 2014, 06:41:16 pm by iamdieselnutmechanic »
Hey there, how you doin?
Reply #25December 15, 2014, 07:11:19 pm
damac
  • 531
« Reply #25 on: December 15, 2014, 07:11:19 pm »
I have been using the auber gages/senders for a while now on my 2 chasis.
I don't have anything bad to say about them.  Egt, coolant and oil pressure.
I have an aircraft alarm that pierces your ears when my set alarms go off.
On my fresh 1.6td at the flange I get 100+ psi on startup.  At stock hot idle it stays around 27psi.  Pressure rises right after startup.  Thats with a windage tray and 36mm oil pump.
1985 turbo diesel jetta
Reply #26December 25, 2014, 02:20:20 pm
manehfr
  • 27
    GOLF MK2 1.9 M-TDI
« Reply #26 on: December 25, 2014, 02:20:20 pm »
I see the same behavior with my AHU, currently running 15w40. Interested to see other responses here.
15... isnt that much? i mean it has turbo... i have a 1.9 m-tdi afn i run on 10w40
GOLF MK2 1.9 M-TDI
Reply #27December 25, 2014, 10:38:39 pm
« Reply #27 on: December 25, 2014, 10:38:39 pm »
Yeah my plan is to run 5w40 Rotella T6, I'm about due for the second oil change on a fresh engine.
