Fixmyvw.com
Author Topic: Step right up  (Read 2820 times)
August 08, 2014, 07:28:32 pm
Dakotakid
  • 1239
Step right up
« on: August 08, 2014, 07:28:32 pm »
HERE is your chance to be a building super, a mechanic, Aaannnnddd a proud VW diesel owner!
http://www.ebay.com/itm/Volkswagen-Jetta-Sedan-Experimental-1984-VW-Jetta-4dr-Sedan-5sp-1-6L-Diesel-53-miles-per-gallon-/121403154962?forcerrptr=true&hash=item1c44312212&item=121403154962&pt=US_Cars_Trucks
Must have been some good stuff.......
(I'm seeing blue!)
« Last Edit: August 08, 2014, 07:30:27 pm by Dakotakid »
Reply #1August 08, 2014, 11:09:27 pm
  • 4393
Re: Step right up
« Reply #1 on: August 08, 2014, 11:09:27 pm »
Must be a plumber in Wisconsin.  What is all going on under the hood?  I bet he could remove all that heavy metal tubing and elbows and gain another 3 MPG.  Then he could use the cruise control.
Additives, heat on fuel lines and on intake is what I read.  But what a spaghetti farm under there.  I will never consider the few extra lines I have on my Rabbit for the WVO system to be a clutter to the engine bay again.  Wow.  Makes you just want to rip into it and clean it out.
Reply #2August 09, 2014, 12:40:20 am
shorttimer
  • 121
Re: Step right up
« Reply #2 on: August 09, 2014, 12:40:20 am »
Too bad it's such a cluster ph*** otherwise it looks like not too bad of a car. Kinda far for me.
S-PAutomotive.com
