VWDiesel Blog
Facebook Group
VWD on Twitter
Model Specific Questions and Info
MK1 Golf/Jetta and B1 Dasher
VW MK1 RABBIT TRUCK FUEL TANK ( ALLOY 18 GAL )
Topic: VW MK1 RABBIT TRUCK FUEL TANK ( ALLOY 18 GAL ) (Read 6359 times)
June 26, 2014, 03:12:57 pm
GEE-BEE
June 26, 2014, 03:12:57 pm »
I got the last one and he will make more.....
Mfg is seenit
http://forums.vwvortex.com/showthread.php?6996462-Aluminum-Caddy-Fuel-Tank
The truck will now need a relief tube installed
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
June 26, 2014, 11:50:19 pm
Moderator
Re: VW MK1 RABBIT TRUCK FUEL TANK ( ALLOY 18 GAL )
June 26, 2014, 11:50:19 pm »
care to share the price you paid? I added an alumimum tank to the back of the Rabbit and was into it for 4 bills. 12 gallon tank, heater tubes, bungs and the sender. Guy had it made for a Jetta and never used it. Price did include press on 3/8 inch line and enough 1/2 radiator hose to go from engine bay to back of the car. Roughly 20 feet pluse an oil filter flange, fittings and two filters. So maybe the price on the tank is only 3 bills less all the rest of that stuff.
June 27, 2014, 10:25:12 am
GEE-BEE
June 27, 2014, 10:25:12 am »
Price was 425.00
sender was 33.50
That should be 3.5 extra over stock
GB
Giles Pump OHC
MK1 JETTA DASH
June 28, 2014, 01:08:57 am
Moderator
June 28, 2014, 01:08:57 am »
Thanks at least now I know I didn't get ripped on my deal. Mostly because of the quality of the tank and all the extras would have been necessary anyway. The guy called me up about a week after I installed it because he found more stuff. When I showed him the install he was loving it. He was sure the right guy got the right deal.
June 28, 2014, 04:00:45 pm
June 28, 2014, 04:00:45 pm »
I wonder how much the 30 gal in my Caddy was? It sure needed the air shocks when full.
July 04, 2014, 09:26:31 pm
DogDiesel
July 04, 2014, 09:26:31 pm »
I saw an Arizona caddy pickup with 24 gallons. 30 gallons. Wow.
Would really be interested in one if 24 or larger.
Wayne
July 21, 2014, 12:55:24 pm
July 21, 2014, 12:55:24 pm »
Good to see someone reproducing them.... The alloy one thats been in rafters for 20 years may get used now... Damb horders... Its only 28 gal.... Imo needs better baffle set up as its going to suck air when low and fuel sloshes
August 17, 2014, 03:04:05 pm
GEE-BEE
August 17, 2014, 03:04:05 pm »
It showed went a bent nipple , filed a claim with fed ex ground
now a freebie, as fed ex paid the claim in full
The nipple looks like a gal I know in a t-shirt..
GB
Giles Pump OHC
MK1 JETTA DASH
