Author Topic: Factory output of a 1.6td  (Read 4000 times)
June 18, 2014, 07:28:10 pm
bryanb
  • 25
« on: June 18, 2014, 07:28:10 pm »
Anyone know of hand what the factory output on the 1.6td is? And if so what what do you think mine is now if I have a t3 Giles pump?
Don't be retarded a glow plug is nothing like a spark plug
Reply #1June 19, 2014, 03:33:03 am
Alcaid
  • 549
Re: Factory output of a 1.6td
« Reply #1 on: June 19, 2014, 03:33:03 am »
How long is a rope.... Being a bit more precise would make it easier to give you a reply
1.6TD came with 60bhp, 70bhp and 80bhp
Are you now running the stock 1.6TD T3 or another T3? Stock one flows 20lbs/min so should be good for about 140bhp but with a turned up 9mm pump normally stops at 120-130bhp
What has been done to your pump? Do you know how much fuel it supplies? (cc), what size piston etc?
'10 VW Passat 1.6TDI Highline
Reply #2June 19, 2014, 05:13:38 am
bryanb
  • 25
« Reply #2 on: June 19, 2014, 05:13:38 am »
Well *** did know their are so many   Variables but it Is a Garrett t3 and I don't know the specifics on the pump but I was told should peak at about 26lbs but have not tested that yet
Reply #3June 19, 2014, 05:35:57 am
« Reply #3 on: June 19, 2014, 05:35:57 am »
The under the hood sticker shows 52 for the non turbo and 68 for TD.
Reply #4June 19, 2014, 06:02:02 am
« Reply #4 on: June 19, 2014, 06:02:02 am »
and 70for the eco, 80 for the GTD...approx.
Garrett made many t3 turbos, which one do you have
Reply #5June 19, 2014, 06:08:49 am
« Reply #5 on: June 19, 2014, 06:08:49 am »
The Man
What are the differences with the GTD. More boost, intercooler.
Thanks.
Reply #6June 19, 2014, 07:12:59 am
Alcaid
  • 549
« Reply #6 on: June 19, 2014, 07:12:59 am »
Eco was 60 not 70 (engine code 1V, 8mm pump without LDA)
Reply #7June 19, 2014, 08:41:00 am
JerryGTD
  • 89
« Reply #7 on: June 19, 2014, 08:41:00 am »
ECO was rated at 44KW or 59HP.
1991 Jetta GL ECOdiesel
Reply #8June 19, 2014, 03:21:46 pm
« Reply #8 on: June 19, 2014, 03:21:46 pm »
My bad...rounding numbers and missed the 6 for 60.
Reply #9June 19, 2014, 07:23:01 pm
bryanb
  • 25
« Reply #9 on: June 19, 2014, 07:23:01 pm »
Tomorrow I will snap a pic of the data plate on the pump and turbo.
