Author Topic: Another exhaust manifold  (Read 5131 times)
May 03, 2014, 09:07:03 am
GEE-BEE
  • 1604
« on: May 03, 2014, 09:07:03 am »
http://www.darksidedevelopments.co.uk/products/tubular-top-mounted-manifold-for-1-9-tdi-with-gtb-turbocharger.html
I was going thru there webste for a well made race pipe for my alu/ pd130 install
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1May 03, 2014, 04:35:20 pm
Syncroincity
  • 727
Re: Another exhaust manifold
« Reply #1 on: May 03, 2014, 04:35:20 pm »
*Add to Wishlist*
Wow. Nice piece, obviously quality. $1265 at today's exchange rate.  :P plus shipping from UK. Yikes.
What turbo is this designed for? This would be a nice unit for a 50-degree Vanagon because of the top-mount position, lifts it up out of the mud a little.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2May 03, 2014, 06:54:09 pm
Re:
« Reply #2 on: May 03, 2014, 06:54:09 pm »
It'll be for the GTB series turbos, which are totally awesome.
You'd be surprised how reasonable shipping can be. Ryan at Darkside sells a lot to North America so he has things pretty dialed.
Reply #3May 03, 2014, 06:56:54 pm
« Reply #3 on: May 03, 2014, 06:56:54 pm »
id buy a tig to build my own vs that price... glad i own one.. :D
Reply #4May 03, 2014, 06:59:40 pm
GEE-BEE
  • 1604
« Reply #4 on: May 03, 2014, 06:59:40 pm »
Giles Pump OHC
MK1 JETTA DASH
Reply #5May 03, 2014, 09:00:44 pm
Re:
« Reply #5 on: May 03, 2014, 09:00:44 pm »
That's the GTB1756VK, same as I'm using. Great turbo!
Reply #6May 04, 2014, 06:33:12 am
GEE-BEE
  • 1604
« Reply #6 on: May 04, 2014, 06:33:12 am »
Is your turbo Electonic or Vac setup
Where did your purchase the turbo from..
Giles Pump OHC
MK1 JETTA DASH
Reply #7May 04, 2014, 09:45:21 am
Re:
« Reply #7 on: May 04, 2014, 09:45:21 am »
Mine is vacuum. I got it from a seller on TDIclub called X-Man. It is a rebuild but comes with its VSR balance sheet and everything.
Reply #8May 04, 2014, 12:54:44 pm
GEE-BEE
  • 1604
« Reply #8 on: May 04, 2014, 12:54:44 pm »
Thanx
I will email Ryan and get the manifold and the Turbo
I will get a downpipe flange and have techtonicstuning make the MK1 tall 2.5 downpipe..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9May 07, 2014, 09:14:57 pm
GEE-BEE
  • 1604
« Reply #9 on: May 07, 2014, 09:14:57 pm »
Ordered today !
I purchased the exhaust flange to make the  downpipe from...
Will see... ;D
Giles Pump OHC
MK1 JETTA DASH
