Author Topic: FS 1992 B3 Passat wagon $5500 obo  (Read 6458 times)
April 27, 2014, 11:09:17 am
bbob203
  • 1789
« on: April 27, 2014, 11:09:17 am »
I need a newer Vehicle for Work so up for sale is my 1992 B3 Passat wagon. Body Has 215,xxx miles on it white with peeling clear coat and a few dings here and there is no rot but a small spot of light surface rust on one of the fenders and a few browned dings. I converted the car last year with a 1996 1z TDi motor present time it has about 264,xxx miles on it. Overall a great car I drive it everyday frequently 100 mile 1 way trips and just drove it to Arizona in October and Maine in December and it performed great the whole time. This thing can haul a lot of stuff and can sleep two comfortably in the back. All the windows work and nothing leaks including the sun roof. The interior is black a rare option and clean with no off smells from smoking or animals. Window tint is peeling. Pictures today.
Boost, EGT, Oil water/temp switched, and oil psi guages in an A pillar pod.
Pd150 intake w/ race pipe.
Rebuilt k14 turbo at time of conversion set to 18psi.
New oil feed and drainlines
VEG .216 injector nozzles in Rebuilt bodies with higher breaking pressures.
12mm cummins 4bt pump built by a professional to run a TDi properly without the ecu. same mileage as the turbo. This was a brand new pump not rebuilt.
2.5'' FMIC from ebay.
MK4 shifter setup w/ TT short shifter and 42 draft design bushings.
Tdi CTN transmision
VR6 pressure plate with TDi disc installed new at time of swap.
Conti timing belt ina rollers and tensioner done at conversion.
Cruise does not work but I will be looking into it soon. (I think its a worn column switch)
B3 AAZ cluster gas and temp guage don't ussually work but it can be resoldered. Tach and MPH speedo work great.
Rabbit spin on filter.
Ac hooked up but needs troublshooting.
Windshield has a horizontal crack midway up passenger a-pillar terminating slightly past the middle but doe not impede drivers view. The rearview mirror also needs attached it fell off when it was really cold.
Bilstein HD struts up front new bushings/bearings.
Facet posi flow lift pump.
Rear shocks probably need replaced and the springs are little tired I have a good set of used sach shocks just have not had the chance to put them in.
R32 front control arm bushings.
Manual glowplug system.
1 year old 1000Cranking Amp battery.
Custom 2.5" straight exhaust dowpipe back the downpipe is 2.25". *when the back is fully loaded with weight the exhaust rubs the axle beam makes noise* It just needs to be cut and rewelded in a different angle so it wont rub.*
Needs a drivers door handle have one on the way
Clear coat is peeling on the roof hood and tailgate.
16" Aluette wheels The tires are snow/ winter tires have 80% tread and no abnormal wear. one of the wheels has a small dent/ flat spot in it from a pothole/curb but it is not noticeable when driven and the cars handles really well.
5,500 obo I have over 7k in it but Didn't save any receipts really so no proof but my word.
All work was done by CRSMP5 and I at his shop.
I need to move this vehicle so make me an offer. I work for American Airlines and would be happy to drive this car too you.
[/URL[URL=http://s1165.photobucket.com/user/bbelty/media/Mobile%20Uploads/20140501_201059.jpg.html]
« Last Edit: May 02, 2014, 05:09:46 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1April 29, 2014, 10:23:17 am
bbob203
  • 1789
Re: FS 1992 B3 Passat wagon $5500 obo
« Reply #1 on: April 29, 2014, 10:23:17 am »
Firm at $5500
« Last Edit: May 02, 2014, 05:10:28 am by bbob203 »
03 Jetta wagon TDi
Reply #2April 30, 2014, 06:47:55 pm
  • 2926
« Reply #2 on: April 30, 2014, 06:47:55 pm »
My dream car,.. but I'm too broke to even insult you with an offer, ha.
Reply #3May 02, 2014, 05:25:28 am
bbob203
  • 1789
« Reply #3 on: May 02, 2014, 05:25:28 am »
Bump pics
03 Jetta wagon TDi
Reply #4May 02, 2014, 07:52:45 am
« Reply #4 on: May 02, 2014, 07:52:45 am »
trades?
Reply #5May 02, 2014, 08:14:01 am
bbob203
  • 1789
« Reply #5 on: May 02, 2014, 08:14:01 am »
For?
03 Jetta wagon TDi
Reply #6May 03, 2014, 10:44:35 am
bbob203
  • 1789
« Reply #6 on: May 03, 2014, 10:44:35 am »
deposit pending
03 Jetta wagon TDi
Reply #7May 04, 2014, 05:51:08 am
« Reply #7 on: May 04, 2014, 05:51:08 am »
its a clean rust free car... i just do not understand selling it myself... i hope the mk4/b5 you feel will be a better car does not make you relize which was better...
if sale falls thru.. feel free to ask me abt the car too.. not seen it in a while.. but it was built "right" with few imo upgrades still to make it perfect... a b4 tdi rad/ac set up would make it perfect.. i have those pieces avaliable for sale too... bbob had interest in the parts before his im going to sell it aspect.. new rad/ac condensor.. well new used for few mo but car hit, then parted few mo ago.. so 2 year old parts with no real use.. car rear ended...
if guy buying car reads this.. if you have interest in the ac/rad parts.. let me know... parts in ne ohio.. i moving to miles away.. but my new addy closer to bbob location.. and i can get the stuff down there for pickup with advance notice.. i expect 2 trips a mo moving my crap to new location..
why b4 tdi ac stuff... r12 vs r134..but heater box and all needs changed and imo tdi rad moves rad hose end tanks for better fit/room at ac comp..
Reply #8May 04, 2014, 05:55:42 am
bbob203
  • 1789
« Reply #8 on: May 04, 2014, 05:55:42 am »
Truly dont want to sell it but its an act of economics. The b5.5 has all the kinks worked but the cam and the engine only has 80k on it with bsm delete, tune, new suspension, tires, new rad, ac cod, much more its practically a new car.
03 Jetta wagon TDi
Reply #9May 04, 2014, 01:21:47 pm
« Reply #9 on: May 04, 2014, 01:21:47 pm »
That is probably the cleanest Passat of that generation I have ever seen.
Reply #10May 21, 2014, 02:16:40 pm
vwsnaps
  • 104
    • Volkshole
« Reply #10 on: May 21, 2014, 02:16:40 pm »
did you sell it ?
cory
www.volkshole.com
Vw Enthusiast Garage
Vw / Audi Dismemberment.
Reply #11May 22, 2014, 06:02:33 pm
bbob203
  • 1789
« Reply #11 on: May 22, 2014, 06:02:33 pm »
Sold today
03 Jetta wagon TDi
