Author Topic: gunning throttle- clutch slips  (Read 5202 times)
March 10, 2014, 07:54:53 pm
92EcoDiesel Jetta
« on: March 10, 2014, 07:54:53 pm »
This is my 92 Eco with governor mod. When I give it a lot of throttle while cruising, I can feel the clutch slip as well as see the tach jump about 300 rpm instantaneously. Same thing from starting from a standstill if I give it too much throttle. This started recently. Does this sound like a worn clutch or oil on the clutch? If I baby it, how many miles will it take before the clutch is totally useless? Trying to do some planning before the inevitable.
Reply #1March 11, 2014, 04:05:23 am
Re: gunning throttle- clutch slips
« Reply #1 on: March 11, 2014, 04:05:23 am »
I regard that as a safety risk, and would fix it sooner rather than later.
Reply #2March 11, 2014, 05:06:55 am
« Reply #2 on: March 11, 2014, 05:06:55 am »
I would check the clutch cable and make sure it is adjusted correctly. If it is the self adjusting style I would reset it as described in the Bentley or on this forum, I forget where I read it.
Reply #3March 11, 2014, 06:59:05 am
CrazyAndy
  • 739
« Reply #3 on: March 11, 2014, 06:59:05 am »
After checking the adjustment of the cable, check through the TDC hole in the bell housing to see if you can see any oil and around the bottom of the bell housing also.  If you end up changing the clutch, I'd replace the rear main seal while in there on principal, anyway.  Same goes for the clutch pushrod seal and the input shaft seal maybe, depending what you see around the bell housing.
Reply #4March 11, 2014, 11:26:54 am
Dakotakid
  • 1240
« Reply #4 on: March 11, 2014, 11:26:54 am »
Indeed, Crazy Andy is right on target except that he forgot the clutch release disc.
And, you probably need a mill on the flywheel to get rid of the blue.
Reply #5March 11, 2014, 11:31:54 am
92EcoDiesel Jetta
« Reply #5 on: March 11, 2014, 11:31:54 am »
The lock nut on the manual clutch cable backed out so the adjustment disc changed position so there was 1/16" instead of the 1/2" gap called for. Readjusted it and will road test later and see if it improves.
Reply #6March 11, 2014, 07:33:58 pm
Gizmoman
  • 1301
« Reply #6 on: March 11, 2014, 07:33:58 pm »
Always nice to go lookin for a problem and find one thats easy to solve!
Let us know the outcome.
Reply #7March 12, 2014, 03:09:21 pm
92EcoDiesel Jetta
« Reply #7 on: March 12, 2014, 03:09:21 pm »
Good test drive.  No more slipping after clutch cable adjustement.  ;D
Reply #8March 12, 2014, 06:33:10 pm
Gizmoman
  • 1301
« Reply #8 on: March 12, 2014, 06:33:10 pm »
Sweet
Thanks for the update
Reply #9March 14, 2014, 05:05:36 pm
CrazyAndy
  • 739
« Reply #9 on: March 14, 2014, 05:05:36 pm »
Excellent, good it was something simple.  However, I would still remove the bottom flywheel cover plate at the bellhousing and check to see if any significant amount of clutch friction material was lost.  Just a precaution, no need to be alarmed.
Reply #10March 17, 2014, 01:48:18 pm
92EcoDiesel Jetta
« Reply #10 on: March 17, 2014, 01:48:18 pm »
I will check behind the cover plate when it gets warmer. Clutch is not slipping anymore. Last time I looked at the flywheel when I was checking the TDC timing mark a few weeks ago it was dry.
Reply #11December 29, 2014, 08:04:34 pm
92EcoDiesel Jetta
« Reply #11 on: December 29, 2014, 08:04:34 pm »
The no more slipping after clutch adjustment was not totally tru. If I gun it hard, it still slipped.
I have been driving it gingerly so as not to burn it out and and a useless vehicle. Now it's 8 months later and the same clutch is back to 100% normal. I can gun it hard now and it does not slip. I only do that when I need to (like when I'm pissed at people tailgating me lol).
What was the problem when it was slipping? I love it when my Jetta fix itself but would like an explanation. What do you think?
Reply #12December 30, 2014, 01:38:10 am
manehfr
  • 27
    GOLF MK2 1.9 M-TDI
« Reply #12 on: December 30, 2014, 01:38:10 am »
maybe the clutch cable was too tight ... and now the clutch is much worn so it has less layer so giving that extra cable edge the oportunity to the cluch grab the flyweel has it should...
GOLF MK2 1.9 M-TDI
Reply #13December 30, 2014, 06:01:14 am
« Reply #13 on: December 30, 2014, 06:01:14 am »
maybe you started wearing into the springs on the clutch hub, extra grip haha.
Reply #14December 30, 2014, 06:11:41 am
« Reply #14 on: December 30, 2014, 06:11:41 am »
Mighta worn off a bit of glaze from the slipping.
My Audi80 recovered on its own from a bad burning.
