Author Topic: fuel injection line (cylinder 2) cracked in half!!  (Read 7415 times)
March 10, 2014, 05:34:14 pm
ReubenG
  • 46
« on: March 10, 2014, 05:34:14 pm »
A) why would this happen? (the pump and lines are only a few years old)
B) I ordered a new line. Replacement seems fairly simple. Anything I should know?? (I have the Bentley)
[/URL][/img]
Reply #1March 10, 2014, 05:34:54 pm
ReubenG
  • 46
Re: fuel injection line (cylinder 2) cracked in half!!
« Reply #1 on: March 10, 2014, 05:34:54 pm »
(1981 vw rabbit diesel 1.6 n/a)
Reply #2March 10, 2014, 06:11:03 pm
« Reply #2 on: March 10, 2014, 06:11:03 pm »
Prothe?
Is the 4th injection pump bolt right? The one at the rear of the pump?
Reply #3March 10, 2014, 06:57:17 pm
ReubenG
  • 46
« Reply #3 on: March 10, 2014, 06:57:17 pm »
yeah, i think it's the bottom rear on the pump. But when purchasing, it was obvious that I needed the #2 line I hope -- http://www.partsplaceinc.com/products/product-detail.aspx?keyword=VW+Diesel+Injection+Line+68-130-302&sku=13651
Reply #4March 10, 2014, 07:02:07 pm
ReubenG
  • 46
« Reply #4 on: March 10, 2014, 07:02:07 pm »
could this happen if I accelerate too quickly? Bentley says to accelerate from 35mpg to 55mpg in like 15 seconds... in 3rd or 4th gear...
Reply #5March 10, 2014, 07:08:57 pm
« Reply #5 on: March 10, 2014, 07:08:57 pm »
Don't lose the little rubber holders, don't adjust timing without loosening the pipes first, keep the pump mounts tight.
Do not stand, sit, or pry on the pipes ;D
Reply #6March 10, 2014, 07:14:36 pm
ReubenG
  • 46
« Reply #6 on: March 10, 2014, 07:14:36 pm »
I'm not planning on adjusting the timing... I can just plug in a new line... right?
Reply #7March 11, 2014, 05:11:03 am
« Reply #7 on: March 11, 2014, 05:11:03 am »
Yes, after verifying that all 4 pump mounting bolts are tight you can "just" plug the line in. Make sure that all the lines smoothly connect to the pump and injector without needing to be pried into position. If they are under stress, they will crack.
Reply #8March 11, 2014, 11:35:08 am
ReubenG
  • 46
« Reply #8 on: March 11, 2014, 11:35:08 am »
I see. Thank you. Also, it seems that it might be difficult to torque the injector line nuts down properly (with the line coming out of them and all...)  just snug them down fairly tight I guess?
Reply #9March 11, 2014, 12:03:54 pm
Dakotakid
  • 1240
« Reply #9 on: March 11, 2014, 12:03:54 pm »
Yeah, just twist the wrench until you feel it give........
No, you simply gently tighten then down really only enough to not leak when running. If you just mindlessly tighten them down, you mushroom the sealing conical tip and then you shell out ANOTHER $23 (or whatever it was) for some more lines. Whatever happened to common sense?
Reply #10March 11, 2014, 01:19:23 pm
« Reply #10 on: March 11, 2014, 01:19:23 pm »
I think spec is 18ft-lbs. basically as loose as possible without leaks, which is surprisingly loose.
Reply #11March 11, 2014, 02:51:36 pm
  • 2926
« Reply #11 on: March 11, 2014, 02:51:36 pm »
Tighten them down a little looser than you think they need it.
 Then watch them when you start it up, swipe a finger to see if it gets wet.
Reply #12March 11, 2014, 02:55:04 pm
« Reply #12 on: March 11, 2014, 02:55:04 pm »
Because the fuel delivery is so low on these cars, you may need to take it for a spin around the block before you'll notice a leak.
Reply #13March 11, 2014, 05:05:39 pm
damac
  • 531
« Reply #13 on: March 11, 2014, 05:05:39 pm »
only been driving these 5 years and have a few being daily driven by family. all old originals and never had this happen.
clamps loose , start each one by hand, then tighten with wrench. finally tighten clamps
1985 turbo diesel jetta
Reply #14March 12, 2014, 04:15:19 pm
ReubenG
  • 46
« Reply #14 on: March 12, 2014, 04:15:19 pm »
thanks to partsplaceinc.com for sending me the part I needed in less than 2 days.  :)
