Author Topic: fuel injection line (cylinder 2) cracked in half!!  (Read 7523 times)
Reply #15March 12, 2014, 06:00:37 pm
ReubenG
  • 46
Re: fuel injection line (cylinder 2) cracked in half!!
« Reply #15 on: March 12, 2014, 06:00:37 pm »
I got it done very easily. I ended up NOT re-installing the clamp for cylinders 1 & 2 injector lines because I would have had to force them closer together... this might have been what caused the breakage of the line in the first place. I observed the vibration of the #2 line shortly after starting the engine and that line probably vibrates the least amount of the 4, so I'm not worried.
Reply #16March 16, 2014, 01:24:36 pm
tyb525
  • 183
« Reply #16 on: March 16, 2014, 01:24:36 pm »
Line #1 or #2 will most likely break very soon with no clamps on them. Believe me, I left the clamps off before I knew any better, and broke a line within 2 days of driving it again. It's amazing how much those clamps actually do.
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #17March 17, 2014, 04:50:14 pm
  • 2932
« Reply #17 on: March 17, 2014, 04:50:14 pm »
 In the pic it looks very close to the aluminum tab on the pump, near where it broke.
 Those weren't somehow vibrating against each other?
 There is a place with more durable #2 lines but I can't remember where,.. ebay?
Reply #18March 25, 2014, 01:02:27 pm
ReubenG
  • 46
« Reply #18 on: March 25, 2014, 01:02:27 pm »
There is no way I can install the clamp without causing extreme pressure to the line. And I don't think there is another location for that clamp...
Reply #19March 25, 2014, 01:22:35 pm
« Reply #19 on: March 25, 2014, 01:22:35 pm »
Then you probably have a bent or wrong line in your set.
Reply #20March 25, 2014, 02:46:05 pm
« Reply #20 on: March 25, 2014, 02:46:05 pm »
Bent or wrong line or you need to loosen all the lines at both the injectors and pump and allow them to "relax" into a position where they're not stressed and then re-tighten and install clamps.
Reply #21March 27, 2014, 09:02:47 am
  • 2932
« Reply #21 on: March 27, 2014, 09:02:47 am »
That pump is rotated so far back and close to the lines,.. you might think about jumping the timing a tooth so you can pull the top of the pump forward and away from the lines,.. makes it easier to change glow plugs too.
