Author Topic: 1.6l A2 NA Injection pump..... leaking  (Read 4010 times)
March 08, 2014, 07:42:53 am
monst
  • 184
« on: March 08, 2014, 07:42:53 am »
 :o
     Yupper...  It's leaking now and can't be ignored...
So I got to deal with it.
    It is leaking at the  last seal next to the
(best way I can describe it) the fuel lines - distributor....
It looks like maybe four torx hold that section onto pump...
   As for the way it is running, it still runs ok... despite a
constant drip. (which will fill a 1/2 pint pretty quick 8oz.   appx. .25liter)
I would like to go at it myself and just replace that one seal....
anyone know the part number of that seal... and what
mysteries :-X :-X lie there..
(like what is going popout and spill all over the floor when
  I remove the fuel distributor from the pump)
       I would rather use a Viton seal.......
* Now if this is something that hasn't been undergone
what are places to get it rebuilt... I live in the northeast
and (looking for a quick turn around.. I need the car running)
Someone near me was saying something of a place in
Connecticut... He got a Kuboda inj. pump rebuilt....there
He couldn't remember the name  (had in the name: Diagnostics) at
the end of the name. prices were very reasonable.
So that is all I can think..
   Thanks , Micky
Reply #1March 08, 2014, 02:03:48 pm
Dakotakid
  • 1239
Re: 1.6l A2 NA Injection pump..... leaking
« Reply #1 on: March 08, 2014, 02:03:48 pm »
The resealing of these pumps has been discussed SO MANY times here.
There is a search function up there in the top right corner. It works.
Reply #2March 08, 2014, 08:00:05 pm
  • 9005
« Reply #2 on: March 08, 2014, 08:00:05 pm »
http://www.vwdieselparts.com/forum/viewtopic.php?t=5311&start=22
http://www.vwdiesel.net/forum/index.php?topic=33164.msg309635#msg309635
Buy the complete seal kit, you are going to need it anyways within the next year. You really should do all the seals while you are at it.
Personally I would never attempt doing this seal with the pump installed in the car. I know others have with success, but knowing what is behind those 4 innocent looking screws is enough for me to take the pump off and do it on the bench. Plus being in the NE things are going to be a lot rustier than what most people from the south expect.
Reply #3March 08, 2014, 08:56:30 pm
JASGTi
  • 61
« Reply #3 on: March 08, 2014, 08:56:30 pm »
As someone who is looking forward to resealing a pump in the near future. While doing it on the car is possible, it is not worth the risk. Plus you will more than likely need to replace all the seals anyway. My pump has now started to leak from the top in addition to the head and the cold start lever.
Reply #4March 09, 2014, 01:25:38 am
« Reply #4 on: March 09, 2014, 01:25:38 am »
There are a bunch of things you could screw up  inside the pump, on-car there are only 2 or 3 and it is a whole lot faster.
Reply #5March 09, 2014, 08:33:38 am
  • 1508
« Reply #5 on: March 09, 2014, 08:33:38 am »
True, but doing the big ring in-car, almost any screwup is game-over.
On the bench, most common screwup is the throttle lever - easy fix. Plus, easy to do the other common leakers and a gov-mod.
Reply #6March 09, 2014, 12:39:53 pm
damac
  • 530
« Reply #6 on: March 09, 2014, 12:39:53 pm »
Ditto, this happened to me once and never again.  Every pump that works that I want to drive that has a tight mainshaft, I break down to clean and reseal.
Its just not worth doing this again.  If one seal is leaking, others are crusty and fused in place and it will be a matter of time before you yank it again.
Use pump lock pin and clamp each sprocket area to the belt so it won't jump teeth.  Pull the pump and break it all down and reseal.  Feed pump back on the same way with keyway and it will pull itself back into place.  Then all you have to do is time it.
A vise and ability to use and make simple tools is all you need.  Some parts should be marked in relation to each other, I like to use nail polish.
If worried about it there is a guy on ebay that sells a video so you can pause step by step.
You could easily do the whole job and have your car back running in a day.  And I did my first one a few years ago, now its easy.
1985 turbo diesel jetta
Reply #7March 11, 2014, 10:33:33 pm
monst
  • 184
« Reply #7 on: March 11, 2014, 10:33:33 pm »
Thanks...
Appreciate the insight.....
   I will look at the possibility of the vid.... on eeb...
It is possible to get a seal kit... that is
    VITON......  bio friendly seals?
Micky
Reply #8March 12, 2014, 09:42:47 am
sgnimj96
  • 166
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #9March 26, 2014, 12:58:55 pm
monst
  • 184
« Reply #9 on: March 26, 2014, 12:58:55 pm »
Yeah,
   Thanks on the link here.
I got my seals the other day...
Going to work on it today.
got to get the pump out.
Monst
Reply #10March 26, 2014, 05:15:10 pm
« Reply #10 on: March 26, 2014, 05:15:10 pm »
Use a sharp scribe to mark every arm you remove in relation to its shaft.  That way you wont go wrong by more than one spline.
Reply #11March 26, 2014, 06:04:36 pm
TimpanogosSlim
  • 591
    Pretty dumb for a smart guy
« Reply #11 on: March 26, 2014, 06:04:36 pm »
This sounds like a good idea.
Also, the trick that amateur watchmakers use is to take a picture with a digital camera every time a part is removed or reoriented.
I got through my first half dozen movements that way. Now i just recognize where the parts go. One train is somewhat like another.
Reply #12March 27, 2014, 10:57:54 pm
monst
  • 184
« Reply #12 on: March 27, 2014, 10:57:54 pm »
Thanks on the tips....
   So I replaced the seal at the hydraulic head.....
slapped it back in... I decided not to delve in
too deep. Too many projects going at once,
   Anyway, pump was out of car for a good day.
My question is this, How long does it take to
crank a dry pump to get the vehicle started.
And is there a bleeder on the ip?
   Micky
Reply #13March 27, 2014, 11:29:51 pm
  • 4393
« Reply #13 on: March 27, 2014, 11:29:51 pm »
Some of us fill the pump through the out bolt and then put the bolt back in place.  Some just put suction on a line at the out line and pull fuel through till they get the pump full.  It will take more cranking than you want to do on a battery to fill an empty pump.
I use a big syringe made for mixing 2 cycle oil to the proper ratios.  A bit of clear line and I just have to remove the line at the needle point and rest and pull again.
Reply #14March 28, 2014, 09:43:40 am
Gizmoman
  • 1301
« Reply #14 on: March 28, 2014, 09:43:40 am »
I installed a 12 volt diesel lift pump purchased at the FLAPS. About six fairly short cranks with the injector nuts backed off and it lit. Pump was rebuilt and empty.
S-PAutomotive.com
