Author Topic: Built 1Y or Frankenengine? (and assorted other questions)  (Read 10630 times)
January 30, 2014, 06:31:16 pm
Formerfreeagent
  • 24
« on: January 30, 2014, 06:31:16 pm »
Alright guys so I have come to the encyclopedia of IDI VW diesel knowledge for some insight. I recently purchased a 1981 Caddy from a friend who has owned if for about 2 years and it has sit with a blown turbo and shot rings for probably the last 12 months. I had to scavenge the head off the 1.6D (non turbo motor with a turbo bolted on) to replace the one on my wife's daily after a fuel nozzle went and destroyed the head that was on the car. I then came across an engine that another friend sold about 8 months ago due to a bad IP and I picked it up for a steal.
So here is where I am right now. I have a caddy that this is going into. I have a 1.6 non turbo bottom end that needs a rebuild. A 1Y engine with some missing accessories and an end power goal of 140-170 Whp and the accompanying *** ton of torque. The goal was just to build the 1Y up (Head is already at a machine shop), bolt on a holset blower and send a pump of too the man Giles himself with the spec sheet and see what kind of damage could be done.
Issue I am having is finding any good information on the 1Y and anybody that has successfully built one for this kind of power and been able to daily drive it. I have seen AAZ's produce this amount of power and more but very rarely do I find a build thread with a "Its a year later and this is what has happened". I know the 1Y engine was a Canadian non turbo version of the AAZ. The heads are similar but not the same the valves are different (This will be a question in a minute) the bottom ends have a longer rod and shorter piston but both have oil squirters. So while I was digging through the forums and coming up pretty dry I started wondering if maybe I should focus on building a frankenengine instead as they seem to have the capability of this power goal and be dailyable. (Cold starts aren't much of a concern in AZ)
This is not a money is no object build. I am a college student with a half decent job and monthly bills. I am planning on cashing out some stock options and using part of my tax return to fund this entire build. I have a strong mechanical knowledge. I have friends that are certified welders. I have access to most metal working tools. I am a CAD student and work well with solid works. My accomplice on this build works for cummins and has plenty of diesel experience however we are NOT mechanical engineers and I have A LOT to learn.  I am comfortable building and designing quite a bit on my own and I am planning to use all of my resources that allow me to pay in beer whenever possible.  ;D
Original Plan....
1Y Head, Port and Polish,
1MM Oversize intake valves (7mm stems) - Where is good source to get these that doesn't have a min. order of 50 like Supertech?
Holset HE211W with a custom built manifold that will get ceramic coating.
Stock pistons with a coated face
Bottom end refresh
Block girdle
Baffled oil pan
Giles Pump and Injectors (Can I send him my 1.6 pump and him build it to properly run a 1.9)
Close ratio 5spd with a Tall 5th (donated by a friend)
Front mount (core donated by a friend)
Water Meth kit (Currently on CL for $125)
Custom intake (working a twin plenum design)
2.75 DP and Full Turbo back dropping off just before the rear axle (Will this cause a risk for valve float?)
Main Studs and Head studs (ARP)
Pyrometer and Boost Gauge...
Goal 20ISH Lbs of boost...
Grand total about $2500... I hope :)
Question for those that are more experienced than I... Will this support and reliably meet my power goal?
OR
Would I be better off going about doing a 1Y head on a 1.6 Block. I know it would be a good idea to source a turbo block for the oil squirters but is it 100% needed. I will need to convert to a mechanical lifters or find a hydro block (which is just more reason to find a good turbo block) basically all the same mods as above.
This is my FIRST realistic build. This will be my daily, my occasional fat track day car and the cross country rig if needed. I have dawned my flame suit incase but I think I have a sound plan so this should be fun.
Thanks All in advance
« Last Edit: January 30, 2014, 06:41:19 pm by Formerfreeagent »
Reply #1January 30, 2014, 07:17:59 pm
wolf_walker
  • 1205
Re: Built 1Y or Frankenengine? (and assorted other questions)
« Reply #1 on: January 30, 2014, 07:17:59 pm »
FWIW, near as I can tell the 1Y is a NA AAZ, some if not all had single stage injectors, a particular NA intake, with or without EGR (I finally found one), the modern molded plastic PCV setup, and I suppose the canadian type serp belt setup.  I don't recall if the compression differs or the oil squirters are not present on it, finding a copy of ETK will help you a bunch.
I'm slowly converting my AAZ into a 1Y more or less, intake, PCV, has a dual out GTI gasser exh mani already.  It's already got a hell of a lot fatter torque curve than a NA 1.6 but nobody would mistake it for a turbo.  Which is plenty for me.
Mentat Text Two
Reply #2January 30, 2014, 07:48:08 pm
Formerfreeagent
  • 24
« Reply #2 on: January 30, 2014, 07:48:08 pm »
Its got mk2 intake similar to the 1.6 NA one, its a plastic upper and mid with a cast bottom. No EGR, PCV is old style on mine I think but I will be putting an oil catch on the engine. My engine is setup V-belt style. I heard some did and some didn't have oil squirters. Checked the block and they are there :D  I'm not gonna lie I am looking for enough power to surprise some of the 1.8t kids (obviously lightly modded or stock cars only) especially from a good roll on the interstate. But I am by no means looking for a VRT stomper... or a corvette eater.
Thanks for the info  ;D
BTW Do you know if the internals are forged? Particularly the crank on the 1Y?
Reply #3January 31, 2014, 09:53:27 am
wolf_walker
  • 1205
« Reply #3 on: January 31, 2014, 09:53:27 am »
I've seen that intake, pretty cool.  I want to say when I was reading up awhile ago that the guts were same PN's as AAZ fwiw.  Other than the pistons.
No reason you can't get as much power as any hopped up AAZ makes out of it given boost fuel and airflow.  Sounds like a cool project.
Mentat Text Two
Reply #4January 31, 2014, 01:45:09 pm
carrizog60
  • 978
« Reply #4 on: January 31, 2014, 01:45:09 pm »
a have a 1y on my passat.
they can handle turbo,no worries on that.
here in europe they had a aluminium intake that looks like gti versions.
i have mine bolted to a tdi transmission,gt2052v turbo,custom 1y intake and it kicks ass.
daily drive,gets  good mileage,can make long trips at jail speeds with no issues and still good economy.
for me its a go!
Portugal
Reply #5February 01, 2014, 07:04:08 am
Gizmoman
  • 1301
« Reply #5 on: February 01, 2014, 07:04:08 am »
FWIW, Giles rebuilt my 1.6 IP to theoretically produce 150 HP on my 1.9 AAZ. I have no idea what the details are but I'll take his word for it. It's definitely  got more grunt than it used to, but my K14 and DIY IC can't keep up with the fuel and my EGT's can hit 1300 pretty quickly.
With the proper air, I think I could have 150 easily
Reply #6February 01, 2014, 08:37:14 pm
Formerfreeagent
  • 24
« Reply #6 on: February 01, 2014, 08:37:14 pm »
Awesome feedback guys. I talked with the machinist today and let him know what the plan was. 1Y big turbo for sure. He said he should have it handled in a couple weeks.
So I have two weeks to find valves for this car. I know I have read speculation that the 8V gasser heads have the same valves as the 1.6's is that true? Does anybody know for sure? I can't find anywhere to get oversized valves for this head but Supertech does sell valves for the 8V head oversized.
Is there a company that makes these valve oversized?
Does anybody know where I can find the valve dimensions?
For you guys with the 1Y's in your dailys, Do you feel like you have more potential? I know the bug is gonna bite and after a while hanging around the 150 hp mark I know I am gonna want more. Do you guys have it there or am I looking at seriously rebuilding and heavily modifying the setup I have here?
Thanks Again.
Ps If Alcaid is out there, do you feel that the Holset Blower I listed above has the guts to reliably boost this lump? I have a friend at cummins and he raves about holset and seems he can pass a long some sort of discount.
Reply #7February 01, 2014, 09:14:55 pm
wolf_walker
  • 1205
« Reply #7 on: February 01, 2014, 09:14:55 pm »
Gonna show my ignorance here but are the AAZ valves the same, or the ABA or it's kin gassers?
Traditionally the exh valves are sodium filled or some such for turbo-heat, I'd do some part number
comparos.
Mentat Text Two
Reply #8February 02, 2014, 05:01:20 am
« Reply #8 on: February 02, 2014, 05:01:20 am »
with 20 ish boost you will not have valve float. You exhaust will have nothing to do with that either. Run you exhaust all the way out from under your car as it will be a loud sooty drone under your car if you end it before the axle beam. Oversized valves can be found, but it is a custom thing and I think the 1y valve wise is similar to the aaz and you probably won't be able to go bigger than 38mm intake and 33mm exhaust.
Reply #9February 02, 2014, 05:56:14 am
carrizog60
  • 978
« Reply #9 on: February 02, 2014, 05:56:14 am »
i think i have that 150hp now,and yeah,with fuel and boost i can have more.
Portugal
Reply #10February 02, 2014, 09:45:34 am
MJF
  • 581
« Reply #10 on: February 02, 2014, 09:45:34 am »
Your plan sounds good. Just forget oversize valves and main girdle, no need for those in such low power build.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #11February 02, 2014, 10:13:59 am
« Reply #11 on: February 02, 2014, 10:13:59 am »
Sorry, I agree with MJF here. I honestly didn't read your entire post and didn't see the main girdle.
We have seen some high numbers with the stock aaz valve size, much higher than 150hp. I was commenting more that if you have the money then bigger valves are great. I put 40mm in my 1.6 and they really breathe.
Reply #12February 03, 2014, 08:50:28 am
Alcaid
  • 549
« Reply #12 on: February 03, 2014, 08:50:28 am »
The 173whp 1.6TD had stock untouched bottom end and untouched AAZ head. The key to the power was turbo (Holset HE211W), modified pump (11mm) and a decent intercooler setup
'10 VW Passat 1.6TDI Highline
Reply #13February 06, 2014, 07:27:15 pm
Formerfreeagent
  • 24
« Reply #13 on: February 06, 2014, 07:27:15 pm »
First of all thanks for all the replies guys I am really glad to hear it sounds like I'm headed in the right direction...
While I do realize that I am not making enough power to really utilize a block girdle I have designed one for a friend of mine that is building a high revving big boost 16V for some local Time Attack racing so its more over that I had to order 4 cause that was the size piece of steel I bought and I sold him 3 and kept one, so why not be EXTRA safe :)
I am now on the fence about the valves, I would really like to do them but I am not sure at what point would I really need them. Like I previously said this is on a budget and I am just broke college student, but I also know that I have a SERIOUS problem when it comes to modding...  ::) ;D So when I say my goal is 150 Whp. I'm not sure how long that will last, so if I can do this right and do it once I would really like too.
Everyone has said that the AAZ/1Y has seen far more than my goal, but how much more? All I have been able to find is about 200 hp.
Alcaid how much boost was that motor pushing? I know he has to have some sort of advantage over me due to the significantly reduced compression ratio that the hybrid motors yield, correct? How much boost should that charger safely flow? 25 lbs daily all the time?
Theman your head's flow numbers are really the reason I want to try and see how much this 1Y head will flow. The Machine shop said they would look at it take some measurements and get back to me about how large we can fit in there. ;)
He has said that do to the engine being Forced Induction he is not going to worry about chamber velocity much if at all, does this sound right?
I looked at the frozen boost setups, being that I am in AZ and summer ambient temps could see 130 how much do you think I would benefit from an ATWIC rather than an ATAIC?
Reply #14February 07, 2014, 02:15:24 am
Alcaid
  • 549
« Reply #14 on: February 07, 2014, 02:15:24 am »
32-33psi ;) The do 30+psi all day long no sweat, that's how they are used in OEM applications. 360° thrust bearing really helps for longevity in high boost applications. You would need less psi for the same whp with the bigger displacement and higher compression. We have tested over 40psi with stock 1.6td compression without failure.
I posted a lot of information on the HE211W turbochargers here: http://forums.tdiclub.com/showpost.php?p=4417949&postcount=238
