Author Topic: Mk1 Jetta - 010 to 020 change over  (Read 7559 times)
Reply #15February 08, 2014, 09:47:39 am
Re: Mk1 Jetta - 010 to 020 change over
« Reply #15 on: February 08, 2014, 09:47:39 am »
not on a mk1..... 2 tabs, 1 slotted thats vertiicle, one wth hole thats horizontal, the studs of the verticle rod go thru the holes...
if the rack was ever replaced, unless sed auto rack, they all came with tabs...
2nd pia... auto bunny gotta go down out the bay, so gotta remove exhaust... the auto and master have room issues to go up..
Reply #16February 08, 2014, 02:05:58 pm
homerj1
  • 433
« Reply #16 on: February 08, 2014, 02:05:58 pm »
Hey CRSMP5,
I'm not sure what you mean by the above? I was going to yank the whole drivetrain, but for the interests of the KISS principle, I am thinking about just leaving the engine in, then pulling the 010 and dropping in the 020.
I'm running a K03 on my 1.6,and have a custom down pipe. Which I'm thinking might interfere with my shifter linkage.....
thanks
Reply #17February 09, 2014, 11:28:54 am
Quantum TD
  • 1195
« Reply #17 on: February 09, 2014, 11:28:54 am »
Be sure to check out the brake boosters. Both cars are German-made, so there shouldn't be a problem. But on USA-made Rabbits vs. Jetta/Convertible/Scircco, there is a difference in the boosters, which means you may need to replace the master with the booster and the pedal pack.
Reply #18February 10, 2014, 02:26:14 am
homerj1
  • 433
« Reply #18 on: February 10, 2014, 02:26:14 am »
Thanks for the heads up, the rabbit is a made in Germany, so I'm assuming the pedals and stuff will line up?
Reply #19February 10, 2014, 04:29:25 am
« Reply #19 on: February 10, 2014, 04:29:25 am »
nk it was last year we went thru his parts from this fit that thread...
the rack has tabs not threaded bolt holes.. bolt holes that are threaded are mk2...
Reply #20February 17, 2014, 10:30:17 am
wolf_walker
  • 1205
« Reply #20 on: February 17, 2014, 10:30:17 am »
And while you're in there...   ;D
Think hard about re-enforcing the spot on the firewall the clutch cable goes through.
They break and are an annoyance to fix later.
Mentat Text Two
