Author Topic: Mobile 1 full Synthtic  (Read 7806 times)
March 16, 2006, 03:28:27 pm
superman293
  • 93
« on: March 16, 2006, 03:28:27 pm »
is mobile 1 full syn, 10w-40  alright to put in my 2000 Tdi?
thanks
Reply #1March 21, 2006, 12:53:03 pm
GoFaster
  • 22
« Reply #1 on: March 21, 2006, 12:53:03 pm »
It will do, but it's not the best choice.
For one thing, Mobil 1 here in North America is not available in a 10w40, so better recheck that viscosity.
For another, it does not meet the latest standards for diesel engines.
'96 Passat TDI (looks stock)
Reply #2March 22, 2006, 06:59:39 am
superman293
  • 93
« Reply #2 on: March 22, 2006, 06:59:39 am »
i cant find any other oil at wallmart or autopart stores, what oil is everybody using?
10W30 is what i used
Reply #3March 22, 2006, 08:27:03 am
GoFaster
  • 22
« Reply #3 on: March 22, 2006, 08:27:03 am »
Canadian Tire has Shell Rotella Synthetic 0w40, which meets the required diesel standards for your engine and is an appropriate viscosity.
PetroCanada OilChangers and distributors can get PetroCanada Duron Synthetic 5w40, which is another good choice. Watch out with this, there are several variations of Duron, you need the Synthetic 5w40 version. It might need to be special ordered in advance, but they can get it.
VW dealers have a special version of Castrol Syntec which is 5w40 and meets VW 505.00, suitable for your engine.
You can also use *any* oil that meets the newer VW 505.01 standard, including those from Elf, Motul, and VW dealers. Shops and distributors that specialize in VW cars should all have, or can get, these oils.
Reply #4March 22, 2006, 06:25:56 pm
81rabbit
oils for tdi's
« Reply #4 on: March 22, 2006, 06:25:56 pm »
the oil most people use is the Mobile 1 Truck & SUV. It was available in 5qt container for ~$20 at walmart until recently in a 5w-40 form..
Mobile is now breaking up the Truck and SUV into two new Truck & SUV oils 5w-30 (for gas) and the 5w-40 (for turbo diesels).
If you go to Walmart right now you will only see the 5w30 weight. Mobile said in a announcment that you probably won't see the reformulated turbo diesel variety until mid march-april.  Use the Shell Rotella for now and then switch to the Truck & SUV (Turbo Diesel) later.
If you have a newer '04 and onward pd diesel engine you'll want to use a different oil.  go the the fuel and lubricant section of tdiclub.com and you'll be an expert in no time.. :)
-J
Reply #5March 22, 2006, 07:12:37 pm
MacGyver
  • 245
« Reply #5 on: March 22, 2006, 07:12:37 pm »
Quote from: "superman293"
Of course, if we knew what part of the world you were inquiring from, you might receive more accurate local assistance.
I'm uncertain my PC supplier in London would be of any significant value to you... this is a Canadian forum so you're in Canada right :roll:  :P
http://www.vwdiesel.net/phpBB/viewtopic.php?t=947
Reply #6March 30, 2006, 05:03:48 pm
hillfolk'r
  • 1532
« Reply #6 on: March 30, 2006, 05:03:48 pm »
ive got 2 gallons of mobil synthetic,, 5-40,its called "delvac 1" i think,,,,,,the place i got it(hopewell auto parts,hopewell junction,ny) had 1 gallon left,,then i asked the counter guy if he had more,he said,yea,right next to the delvac 1 theres bottles with the "detroit diesel" labels on them,,its the same thing,,they make it for DD also,,, was same price,,i think it was around 25-28 a gallon,do they still make this stuff?    ?????                                  this was about a year ago,,,,,im changin mine this weekend,first synthetic fill :D ,i got about 3000 mi onit,,and its runnin great,,,knowing mobil,they "changed" the name of it or somethin
Throttle cables ftw
Reply #7April 01, 2006, 06:49:05 pm
moosiah
  • 106
oil, oil toil an' trouble!!!
« Reply #7 on: April 01, 2006, 06:49:05 pm »
Hi there... I buy ' RPM Dello' 10/40 at Costco for about 66$ a case of 6 gals, I've only seen the shell stuff once...  :)
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #8April 03, 2006, 09:13:01 am
MrDave
  • 41
« Reply #8 on: April 03, 2006, 09:13:01 am »
I run DEO synthetic from Caterpillar.
It's readily available from Caterpillar dealers, and
it's rebranded Delvac1.
-Dave
Reply #9May 10, 2006, 01:18:38 pm
Rat407
  • 289
« Reply #9 on: May 10, 2006, 01:18:38 pm »
You can also run AMSOIL's 5w-40 European oil. It is VW 505 compliant.  https://www.amsoil.com/StoreFront/afl.aspx
If you can't find a local dealer or place to purchase it let me know.
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #10May 14, 2006, 04:29:46 pm
tdi jerry
  • 1
Re: Mobile 1 full Synthtic
« Reply #10 on: May 14, 2006, 04:29:46 pm »
Quote from: superman293
thanks
you need to use a diesel oil .i use mobil delvac 1 5w40 synthetic in my 2000 vw beetle tdi.mobil is coming out with mobil 1 turbo diesel 5w40 soon. you can order the delvac 1 5w40 from avlub.vw wants you to run a 5w40 synthetic oil in that engine.  :D
jerry
Reply #11May 18, 2006, 10:36:05 am
Ziptar
  • 565
« Reply #11 on: May 18, 2006, 10:36:05 am »
Used to be Mobil1 Truck and SUV 5-40 Synthetic was the stuff to use.
Mobil1 recently "reformulated" their Mobil 1 Synthetic Line.
Now Mobil1 Truck and SUV is "5-30 for Gasoline Engines"
The new 5-40 (which is delvac1 synthetic) is Mobil 1 Turbo Diesel Truck 5W-40
Still waiting for my local Wally World to get the  TDT 5-40 in. I used Shell Rotella-T 5-40 Synthetic on my last oil change.
