Author Topic: Glowplug pushbutton..  (Read 13860 times)
November 26, 2013, 10:17:20 am
bbob203
  • 1789
« on: November 26, 2013, 10:17:20 am »
going to have to rig up a glowplug system since I'm going to maine next week.  asap looking for advice on what kind of button ought I use.
« Last Edit: November 27, 2013, 02:33:07 pm by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1November 26, 2013, 11:20:51 am
Re: Gloowplug pushbutton..
« Reply #1 on: November 26, 2013, 11:20:51 am »
I would recommend using a relay/solenoid in order to limit the current through the momentary switch.  Use a momentary switch rated for the current needed for the relay/solenoid trigger.
Reply #2November 26, 2013, 12:27:30 pm
« Reply #2 on: November 26, 2013, 12:27:30 pm »
Yeah, one of those kinds of buttons that when you push on it  the electricity flows but take your finger off and it stops.  Pushing button turns on relay, relay sends big current draw to Glow plugs, car starts, everyone happy.
Reply #3November 26, 2013, 12:31:42 pm
bbob203
  • 1789
« Reply #3 on: November 26, 2013, 12:31:42 pm »
yea I'm gonna get a cheapo starter solenoid for now activate it with the button and figure the rest out later.
03 Jetta wagon TDi
Reply #4November 26, 2013, 12:37:30 pm
« Reply #4 on: November 26, 2013, 12:37:30 pm »
Don't forget you need a fuse between Glows and that relay.  Might just use the one on the firewall.  Disconnect OEM wire and replace with Relay feed.
Room for Relay near fender behind battery and near Transmission.  Grab a ground from there as well.
Reply #5November 26, 2013, 01:08:04 pm
bbob203
  • 1789
« Reply #5 on: November 26, 2013, 01:08:04 pm »
this car was a petrol mobile before. I will fuse the connection from battery to solenoid and solenoid to glowplugs. 80amp fuse from battery to solenoid and 60 amp from solenoid to glowplugs. A benz guy diesel guy I know advised marine supply stores sell nice button luckily we have a few since I'm on the ohio river.
03 Jetta wagon TDi
Reply #6November 26, 2013, 05:06:54 pm
RustyCaddy
  • 395
« Reply #6 on: November 26, 2013, 05:06:54 pm »
Something like this works:
http://www.ebay.com/itm/1-EACH-50-AMP-RELAY-HARNESS-SPDT-12V-BOSCH-STYLE-NEW-/380745471083?pt=Car_Audio_Video&hash=item58a632d46b&vxp=mtr
wired to the battery and using the standard glow plug wire as the trigger if you wanted to keep the stock relay setup (if equipped with post ignition secondary glow relay for instance), then into the Vince Walden style fused and separate glowplug wires. Works pretty well.
Reply #7November 26, 2013, 06:11:40 pm
dieseljunkie69
  • 47
    81 Jetta
« Reply #7 on: November 26, 2013, 06:11:40 pm »
A start solenoid needs low amperage to operate (large duty relay is all), so it should be fine to just have a hot wire to a capable switch on the dash then to the solenoid.
I'm That Guy.
Reply #8November 26, 2013, 06:36:51 pm
RustyCaddy
  • 395
« Reply #8 on: November 26, 2013, 06:36:51 pm »
Thats true, IIRC the standard glow plug wire only delivers the amperage that the relay signal is drawing if using the stock relay setup, not the the amperage it could deliver if connected directly to the glowplugs.
Reply #9November 27, 2013, 02:06:08 pm
bbob203
  • 1789
« Reply #9 on: November 27, 2013, 02:06:08 pm »
Scored some good stuff at napa today 44 bucks!
03 Jetta wagon TDi
Reply #10November 27, 2013, 02:34:27 pm
bbob203
  • 1789
Re: Glowplug pushbutton..
« Reply #10 on: November 27, 2013, 02:34:27 pm »
Now just have to figure out how to activate the light when I push the button. It looks for ground to come on.
03 Jetta wagon TDi
Reply #11November 27, 2013, 02:52:26 pm
dieseljunkie69
  • 47
    81 Jetta
« Reply #11 on: November 27, 2013, 02:52:26 pm »
Why do you need the light on when you are pushing the button??? That seems like an unnecessary step.
I'm That Guy.
Reply #12November 27, 2013, 02:54:52 pm
bbob203
  • 1789
« Reply #12 on: November 27, 2013, 02:54:52 pm »
I don't need it but its one of those touches that a person buying the car might like and see attention to detail.
03 Jetta wagon TDi
Reply #13November 27, 2013, 03:22:30 pm
dieseljunkie69
  • 47
    81 Jetta
« Reply #13 on: November 27, 2013, 03:22:30 pm »
Ahh yes, attention to detail. Wire in a separate light right above that push button?
I'm That Guy.
Reply #14November 27, 2013, 03:25:26 pm
bbob203
  • 1789
« Reply #14 on: November 27, 2013, 03:25:26 pm »
Yes i could but I want the cluster one to work  ;D
03 Jetta wagon TDi
