Author Topic: AAZ return line help  (Read 2017 times)
November 24, 2013, 06:18:51 pm
Jagerauto
  • 144
« on: November 24, 2013, 06:18:51 pm »
Hey guys finally got my motor in! I. Need to finish the return line before I can finish the exhaust.
What size is the banjo bolt into the block?
I'm using a T3 turbo, I ordered a flange for it with a -10AN fitting. So I need an adapter from the thread on the block with a 90 into a -10AN. Then a hose.
Don't want this to leak. So please help!
Reply #1November 24, 2013, 06:56:45 pm
Re: AAZ return line help
« Reply #1 on: November 24, 2013, 06:56:45 pm »
IIRC it is 22mm.
Reply #2November 24, 2013, 08:57:34 pm
Jagerauto
  • 144
« Reply #2 on: November 24, 2013, 08:57:34 pm »
Something like this then?
http://bit.ly/1esFm27
Reply #3November 25, 2013, 04:54:29 am
« Reply #3 on: November 25, 2013, 04:54:29 am »
yes, the a/n and JIC are the same so any local hydro shop should have the JIC. I like JIC as it is steel and the aluminum a/n fittings and I don't get along well.
Reply #4November 26, 2013, 07:37:27 am
stewardc
« Reply #4 on: November 26, 2013, 07:37:27 am »
Yup, this is what you need. Take the banjo bolt to any good hydraulic shop and they've got the fitting.
