Author Topic: What and where is a good place to order a pyrometer for 1.6TD?  (Read 5378 times)
November 13, 2013, 10:36:23 am
SR Heer
  • 199
« on: November 13, 2013, 10:36:23 am »
I am planing on putting in TB and pyrometer for 1.6TD while swapping out 92 Jetta and into 82 Caddy - looking for a good place to buy
Thanks
« Last Edit: November 13, 2013, 02:40:11 pm by SR Heer »
Reply #1November 13, 2013, 12:12:56 pm
damac
  • 531
Re: What and where is a good place to order a pyrometer for 1.6TD?
« Reply #1 on: November 13, 2013, 12:12:56 pm »
I only use auber instrument gages now.   Kind of expensive but I learned my lesson with ebay cheapos breaking.
Only thing that sucks about them is they can only read one input at a time so if using to monitor and set alarms for critical things you need to buy more than one controller.  if you don't have a place to mount them they also sell little boxes to protect the guts and you can velcro them somewhere or something, otherwise lots of wires hanging.
1985 turbo diesel jetta
Reply #2November 13, 2013, 04:03:48 pm
« Reply #2 on: November 13, 2013, 04:03:48 pm »
A million times this has been discussed. Westach and aircraft spruce are very good. The micro 1000 probe is all I would ever use for the pyro.
Reply #3November 14, 2013, 08:18:57 am
DogDiesel
  • 210
« Reply #3 on: November 14, 2013, 08:18:57 am »
I was expecting to see pages of info.    ???
I typed in 'pyrometer' and got one hit.  This one.
What search strings are best used?
Understand as moderators, the potential for repetitve topics, but for the newbie, the search engine must work.
Wayne
Reply #4November 14, 2013, 09:12:28 am
« Reply #4 on: November 14, 2013, 09:12:28 am »
Try 'EGT gauge'.  You'll get 26 pages of threads...
Reply #5November 16, 2013, 06:18:59 am
deepgrooves74
  • 68
    • This is my build thread... Bucket.
« Reply #5 on: November 16, 2013, 06:18:59 am »
I bought mine from McNally... It is a dual gauge for boost and EGT. The boost uses a sensor to read pressure with an analog face, and the EGT uses a probe with a digital readout...
http://www.mcnallyelectronics.com
Fairly expensive, but sweet...
Reply #6November 16, 2013, 08:15:06 am
bbob203
  • 1789
« Reply #6 on: November 16, 2013, 08:15:06 am »
I dont quite understand how those egt guages read with only xx.x digits  ???
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #7November 16, 2013, 08:36:29 am
deepgrooves74
  • 68
« Reply #7 on: November 16, 2013, 08:36:29 am »
It's just a temperature... Reads to 4 digit temps.
This webpage which refers to the gauge that I bought says it is good to 1873 deg F.
You actually had me worried for a minute, and I had to check again. I knew I wouldn't have bought a gauge that would be so limited!
Hopefully I never see those temps!
http://www.mcnallyelectronics.com/egt_fx100_boost.htm
« Last Edit: November 16, 2013, 10:02:45 am by deepgrooves74 »
Reply #8November 16, 2013, 08:01:26 pm
« Reply #8 on: November 16, 2013, 08:01:26 pm »
Yup, my digital is 4 digits.
http://www.youtube.com/watch?v=Vzfp0dxPlmQ
Reply #9November 16, 2013, 08:04:44 pm
deepgrooves74
  • 68
« Reply #9 on: November 16, 2013, 08:04:44 pm »
8v that was awesome! Now I want to test mine in the same manner!
Reply #10November 17, 2013, 03:57:07 am
bbob203
  • 1789
« Reply #10 on: November 17, 2013, 03:57:07 am »
I was thinking where is this going ok ok ok yep he's doing it blow torch time.
03 Jetta wagon TDi
Reply #11November 19, 2013, 05:48:49 am
Gizmoman
  • 1301
« Reply #11 on: November 19, 2013, 05:48:49 am »
I used this probe (for EGT) it's very fast.
http://thesensorconnection.com/egt-probes/all-egt-probes/egt-probe-diesel-biodiesel-fast-response-18-diameter
And this gauge
http://thesensorconnection.com/gauges-pyrometers/all-gauges-pyrometers/4-channel-digital-thermocouple-pyrometer-gauge
I also have sensors for intake air temp (post IC), water temp, and oil temp. The gauge displays all four in various formats. Cheap - no. Informative - very.
Reply #12November 19, 2013, 05:59:20 am
bbob203
  • 1789
« Reply #12 on: November 19, 2013, 05:59:20 am »
Your van must be decked out like a airplane.
03 Jetta wagon TDi
Reply #13November 19, 2013, 06:17:49 am
Gizmoman
  • 1301
« Reply #13 on: November 19, 2013, 06:17:49 am »
After a few hits on the libby bong, it feels like one ;D
Reply #14November 20, 2013, 05:32:19 pm
Syncroincity
  • 727
« Reply #14 on: November 20, 2013, 05:32:19 pm »
Second on the Micro 1000 (from Aircraft Spruce) or other small probe; it responds instantly.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
