Author Topic: AAZ and AHU - same timing cover?  (Read 7336 times)
October 11, 2013, 10:15:59 pm
JimEG
  • 32
« on: October 11, 2013, 10:15:59 pm »
Thanks
Reply #1October 12, 2013, 09:25:40 am
Re: AAZ and AHU - same timing cover?
« Reply #1 on: October 12, 2013, 09:25:40 am »
Upper cover?  No, they are different due to the additional timing belt roller that the AHU sports between the pump and cam.
Reply #2October 12, 2013, 12:31:45 pm
Re:
« Reply #2 on: October 12, 2013, 12:31:45 pm »
With the extra piece would it work if you had the same backing piece?
Reply #3October 12, 2013, 01:58:41 pm
« Reply #3 on: October 12, 2013, 01:58:41 pm »
The AHU cover and backing plate will work on an AAZ, but not the other way around.  The AAZ cover will interfere with the roller on a AHU.
Reply #4October 12, 2013, 07:21:10 pm
JimEG
  • 32
« Reply #4 on: October 12, 2013, 07:21:10 pm »
Ok. Thanks for the info. I'm looking for a non-cracked upper timing cover with the retaining bolt? for my AAZ.
Reply #5October 12, 2013, 07:32:43 pm
« Reply #5 on: October 12, 2013, 07:32:43 pm »
Last I checked they were still available new from VW for $70ish.
Reply #6October 12, 2013, 07:40:54 pm
JimEG
  • 32
« Reply #6 on: October 12, 2013, 07:40:54 pm »
That sounds reasonable. Thanks. I didn't expect to be able to go to a dealer for parts for this engine. Am I wrong?
« Last Edit: October 12, 2013, 07:59:47 pm by JimEG »
Reply #7October 12, 2013, 07:59:25 pm
« Reply #7 on: October 12, 2013, 07:59:25 pm »
I just checked 1stvwparts.com and they are selling it for $60 now.
Reply #8October 12, 2013, 08:01:08 pm
JimEG
  • 32
« Reply #8 on: October 12, 2013, 08:01:08 pm »
What vehicle do I use to search for my engine?
« Last Edit: October 12, 2013, 08:03:15 pm by JimEG »
Reply #9October 12, 2013, 08:03:29 pm
bbob203
  • 1789
« Reply #9 on: October 12, 2013, 08:03:29 pm »
96 turbodiesel mk3/b4
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #10October 12, 2013, 08:06:11 pm
JimEG
  • 32
« Reply #10 on: October 12, 2013, 08:06:11 pm »
This place only lets me search by vehicle year and make and doesn't give me the option to select an engine type - it auto fills results for a gas engine.  It must work. LibbyD was able to search the timing cover. ???
Reply #11October 12, 2013, 08:07:15 pm
bbob203
  • 1789
« Reply #11 on: October 12, 2013, 08:07:15 pm »
perhaps by p/n??
03 Jetta wagon TDi
Reply #12October 12, 2013, 08:08:52 pm
JimEG
  • 32
« Reply #12 on: October 12, 2013, 08:08:52 pm »
I just noticed these guys are about 45 minutes from me. I'll call them Monday. Is 1stvw where I should get my parts then?
Reply #13October 12, 2013, 08:18:05 pm
« Reply #13 on: October 12, 2013, 08:18:05 pm »
1stvwparts is a dealership backdoor site.  The part # for the cover is 028109127J.  You're going to want to acquire a copy of ETKA or use Vag-cat or similar for part#s.
Reply #14October 12, 2013, 08:36:35 pm
JimEG
  • 32
« Reply #14 on: October 12, 2013, 08:36:35 pm »
Excellent. Thanks. Any suggestions on where I might use/share/obtain a free copy ETKA or Vag-cat?
 I found this, but I don't read Russian. http://www.auto-parts.spb.ru/cat/au/au.mycat?cl=dr2000
« Last Edit: October 12, 2013, 08:49:16 pm by JimEG »
