Author Topic: 1.6 IDI intakes  (Read 5127 times)
July 20, 2013, 10:42:08 am
wut_cel
  • 34
1.6 IDI intakes
« on: July 20, 2013, 10:42:08 am »
What're you IDI guys using for intakes? The OE runner intake that connects is falling apart on my 1.6TD and am winding if anyone had a good idea on what to run instead. I was looking for a Mandela bent pipe to fit in the same spot with a barn on not for the PCV to run into and just stick a come filter in the other end. Thoughts, opinions, links?
Cheers,
Jordan
Reply #1July 20, 2013, 05:39:37 pm
jseeley
  • 106
Re: 1.6 IDI intakes
« Reply #1 on: July 20, 2013, 05:39:37 pm »
I'm using "ceet" aviation ducting.
http://www.aircraftspruce.com/catalog/appages/ceet.php?clickkey=19469
pic->
I went with 3" but I also modified my airbox a bit to fit that size.
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #2July 21, 2013, 02:05:26 am
carrizog60
  • 978
Re: 1.6 IDI intakes
« Reply #2 on: July 21, 2013, 02:05:26 am »
go to scrap yard and find another?
Portugal
Reply #3July 21, 2013, 08:35:04 am
wut_cel
  • 34
Re: 1.6 IDI intakes
« Reply #3 on: July 21, 2013, 08:35:04 am »
I was hoping to find a more permanent solution. The ones from the yards will be just as bad.
That flex pipe is a good idea, I'd have to get
creative on the PCV port
Reply #4July 21, 2013, 10:50:00 am
Re: 1.6 IDI intakes
« Reply #4 on: July 21, 2013, 10:50:00 am »
They are available on ebay, in silicone, made by one of the members here. If you've got the skills to do it, I guess you could also buy a couple mandrel bends and cut and weld them to make that shape, then use a regular straight silicone coupler to connect it to the turbo.
Reply #5July 24, 2013, 03:55:44 pm
wut_cel
  • 34
Re: 1.6 IDI intakes
« Reply #5 on: July 24, 2013, 03:55:44 pm »
Got a link? All I'm coming up with is the cold side turbo to manifold silicone pieces.
Reply #6July 26, 2013, 10:21:18 pm
  • 2931
Re: 1.6 IDI intakes
« Reply #6 on: July 26, 2013, 10:21:18 pm »
 I think GEE BEE or some name like that had them for sale in the clasifieds,.. then sold the mold to someone who sells them on ebay.
You might be able to find the post and seller on your own
if someone can't come up with the ebay seller's name.
 $65 or something like that, but they are silicone,.. wish they had left the blowoff port off, they might have fixed that by now.
Reply #7July 27, 2013, 06:33:12 am
Gizmoman
  • 1301
Re: 1.6 IDI intakes
« Reply #7 on: July 27, 2013, 06:33:12 am »
Cheers,
Jordan
You can get rubber DWV elbows (45's, 90's and couplers) and black ABS pipe from Home Depot. They sell short (I think 3') sections of DWV pipe (drain waste vent) pipe so you don't have to get a 20 footer. It's all in the same aisle in plumbing. 3" should work but I'm not sure. The rubber elbows usually come with band clamps.
Reply #8July 27, 2013, 12:02:56 pm
Re: 1.6 IDI intakes
« Reply #8 on: July 27, 2013, 12:02:56 pm »
This will work for the "suction" side of the  turbo.. but between turbo and intake manifold it will not.
I have been down that road many times.. and nothing but silicone will do.
Reply #9July 27, 2013, 01:05:48 pm
wut_cel
  • 34
Re: 1.6 IDI intakes
« Reply #9 on: July 27, 2013, 01:05:48 pm »
Good to know, I'm looking for the suction side.
Reply #10July 27, 2013, 02:01:10 pm
Gizmoman
  • 1301
Re: 1.6 IDI intakes
« Reply #10 on: July 27, 2013, 02:01:10 pm »
That's the way I understood it ;D
As 8V said, it's not gonna work on the pressure side
The PO on my bus used that (DWV stuff) with a cone filter and it worked fine.
I'm building a huge filter housing and will figure something else out, but it should work for you and is pretty cheap.
« Last Edit: July 27, 2013, 02:03:42 pm by Gizmoman »
Reply #11August 15, 2013, 10:56:11 pm
GEE-BEE
  • 1604
Re: 1.6 IDI intakes
« Reply #11 on: August 15, 2013, 10:56:11 pm »
1.6TD SNORKEL
I MADE THEM IN TWO CONFIGURATIONS
T2/T3/K14 OR K03 MODEL
EBAY SELLER
MOOGIE2498
OR
MK1AUTOHAUS STOCK THEM
i MAKE ALL THE DIGGERENT COOLANT HOSES
i MAKE ALL THE HOSES FOR THE VANAGON MODELS AND THE AUDI 2.0 T 240 HP MOTOR SWAP
SORRY FOR THE CAP'S
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
