VWDiesel Blog
Facebook Group
VWD on Twitter
TDI Engine -General Info
1z upgrades
Topic: 1z upgrades (Read 6524 times)
July 13, 2013, 01:09:22 am
Baller
1z upgrades
July 13, 2013, 01:09:22 am »
Hi all, I have a 1z tdi [90 hp] engine fitted in my mk1 Golf you guys seem to know your stuff when it comes to tuning these engines, Can any body give me a list of bolt on mods that would improve the performance and what power I'm likely to get with these mods
many thanks Baller
July 13, 2013, 01:20:58 am
Re: 1z upgrades
July 13, 2013, 01:20:58 am »
Is it the electronic pump controlled via computer? Or have you gone mechanical?
We need details
. Nozzles, turbo, intake and exhaust. The same rules apply for every engine. Move more air more effectively, keep the heat down, and inject as much fuel as possible. = POWER.
The 1Z has the stupid tiny good for no more than 15psi GT-15. First step would be to replace that really, its a SUPER bottleneck.
July 13, 2013, 07:23:10 pm
Baller
Re: 1z upgrades
July 13, 2013, 07:23:10 pm »
Has the standard fly by wire pump on it, If I was to replace the turbo with another which would be a fairly easy replacement and what car do I look out for that would have the better turbo fitted to it, same goes for injectors and pump
July 13, 2013, 07:25:22 pm
Re: 1z upgrades
July 13, 2013, 07:25:22 pm »
Was the engine originally equipped with an automatic or standard tranny?
Any turbo that will suit your needs would be the best choice. All other 8v turbo diesel manifolds bolt up to this head, but will pretty much only work with the turbo they are desgined for. Nothing will be a complete bolt up affair.
July 14, 2013, 06:22:19 am
homerj1
Re: 1z upgrades
July 14, 2013, 06:22:19 am »
In my AHU, I found the nozzles to be a quick easy way to increase your getup & go.
July 15, 2013, 10:19:38 pm
Re: 1z upgrades
July 15, 2013, 10:19:38 pm »
Replacing the nozzles is good because you get bigger and cleaner nozzles in there, I feel that even getting your old ones cleaned up would probably do wonders.
Nozzles and a Tune are #1 and #2 if you have a stock Electronic Pump.
July 15, 2013, 11:35:33 pm
410
Re: 1z upgrades
July 15, 2013, 11:35:33 pm »
Check out the evry mod. You get a noticeable increase for the cost of a resistor, a switch and a bit of wiring. Best bang for your buck by far!
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles. Sold!
July 16, 2013, 12:57:21 pm
myke_w
Re: 1z upgrades
July 16, 2013, 12:57:21 pm »
Most of the parts for the best "bang for buck" upgrade for the 1z / AHU are probably available in a junkyard (breaker) near you.
You can fit the VNT based induction system (all turbo related inlet / exhaust parts / oil lines and supports), ECU and N75 from an AFN code engined golf.
Then score a 1749VA turbo from a passat or audi a4 tdi (PN - 038145702G and get a tune (w / 3 bar map) and some nozzles and you'll be good for 150hp or more.
Most of this is plug and play.
For the amount of money you'd spend - especially since this is all considered junk by this point in the UK - there's no config that I can think of that comes close for the money.
July 17, 2013, 05:23:00 pm
Baller
Re: 1z upgrades
July 17, 2013, 05:23:00 pm »
This is great stuff guys, I like hunting through the local breakers and so I realy do appreciate your feed back, thanks alot.
July 18, 2013, 12:32:55 am
Re: 1z upgrades
July 18, 2013, 12:32:55 am »
look for good rover pumps and be a supply..
myke been playing the uk piece/part game on his... but lives here.. what it sounds like is a et up he is playing with even...
July 20, 2013, 10:13:10 pm
Smoker
Re: 1z upgrades
July 20, 2013, 10:13:10 pm »
Quote from: myke_w on July 16, 2013, 12:57:21 pm
Which generation passat are we talkin' here?
1z upgrades
