Author Topic: Injection pump bracket.  (Read 2049 times)
May 25, 2013, 09:33:31 pm
Gator79
  • 53
« on: May 25, 2013, 09:33:31 pm »
Will a mk2 pump bracket work in a mk1 along with a gasser pass side motor mount?
Reply #1May 27, 2013, 06:20:18 am
Re: Injection pump bracket.
« Reply #1 on: May 27, 2013, 06:20:18 am »
I think you would want a MK3 AAZ or AHU/1Z TDI with the 50mm hole (1 piece pulley).
The MK2 uses a very similar support for the pump mount as the MK1. The only difference is there is no motor mount attached to it.
I'm not sure if there are 3 mounting points on the mk2 block for the mk3 bracket though. If I remember I'll have a look next time I'm in the shop.
Reply #2May 30, 2013, 12:56:25 am
  • 2932
« Reply #2 on: May 30, 2013, 12:56:25 am »
 You mean weld the gasser bushing holder onto the diesel bracket?
Reply #3May 30, 2013, 06:55:43 am
« Reply #3 on: May 30, 2013, 06:55:43 am »
I think I've seen someone cut the pump bracket and then use the gasser motor mount as well. I'm not overly excited about that idea though.
