Use the search there are a few threads ont his already. But to sum it up, the stock crank sprocket and nose of the crankget messed up and your timingbelt will slip and destroy your motor.
Before the TDI crank gear fix appeared
What are the symtoms of a loose pulley, If you havent been able to get access to it yet,to physicly look at it.Is there any noises to listen out for, ( mine engine make a slight wirring noise when cold ,it comes & goes every few seconds )or is there a wobbling of the belt or something ?
I think it's a combination of the serpentine belt,which adds a lot of load to the crank snout,and the harmonic balancer,as it's quite heavy.
There is an updated balanced,and a one way clutch type alternator pulley that is supposed to solve the problem,if it hasn't happened yet.
